Where Am I Going Wrong in Calculating the Force Between Two Bar Magnets?
  • Thread starter Thread starter Mutaja
    Force Magnets
The discussion revolves around calculating the force between two bar magnets with a 1mm thick copper gap. The initial calculation used an incorrect area unit and omitted a factor of 1/2 in the formula. After correcting the area to 0.00025m² and including the missing factor, the recalculated force is approximately 24.87N, which aligns with expectations. Participants emphasize the importance of unit consistency in calculations. The user appreciates the feedback, acknowledging their errors in the initial approach.
Mutaja
You're given two bar magnets as shown below. In the gap between the two bar magnets, there's a bit of copper that's 1mm thick. The area of the bar magnet is 2.5cm2, and the flux density is 0.5T. Compute the force between the two bar magnets.
So the force is given by this formula:
F = B * H * A
H = \frac{B<sub>∂</sub>}{µ<sub>0</sub>} = \frac{0.5T}{4∏ * 10^-7} = 397887
F = 0.5T * 397887 * ##2.5cm^2## = 497385.
The answer I get is about 20 000 times bigger than what I'm expecting.
Where am I going wrong?
F is the force.
B is the flux density in the air gap.
H is the field strength in the air gap.
A is the area in the air gap.
I'm sorry for the use of the wrong symbol, but ∂ was the closest I could get.
Also, I realized that I have a gap filled with copper instead of air, just as I was about to post this. I have no examples involving gaps with anything else than air as far as I'm aware. I will keep looking for this and update this post if I find anything.
Any input is appreciated.
Well, for one thing, you are sloppy and inconsistent with the units of your calculation. Is area supposed to be in cm^2 or m^2? It makes a difference.
I'm sorry for this. 2.5cm2 should be 0.00025m2.
Also, I've overlooked the fact that my equation should contain 1/2.
I therefore get 24.87N, and that looks alright.
Thanks for your input, even if it's just to let me know I'm not doing my work properly.
