Why Do Force Constants of DCl and HCl Differ by 10 N/m?
The discussion centers on the differing force constants of HCl (477.8 N/m) and DCl (487.95 N/m), raising questions about the reasons behind a 10 N/m difference. It is suggested that the bond strength of DCl may be greater than that of HCl, but the variation is relatively small (about 2%). The harmonic approximation indicates no difference in force constants, yet the introduction of anharmonic terms complicates this, as the zero-point energy for DCl is lower, affecting the potential well's shape. This leads to a change in the force constant, as it is not constant in anharmonic systems. The conversation also touches on the importance of mass in determining vibrational frequencies and how anharmonicity can cause the force constant to vary with displacement. The discussion references experimental data and theoretical frameworks, including the Morse potential, to explain these phenomena.
Steven Hanna
The force (spring) constant of HCl 477.8 N/m, and the force constant of DCl is 487.95. Why should these values differ by 10 N/m? Is a D-Cl bond somehow stronger than an H-Cl bond?
Chemistry news on Phys.org
Think in terms of percentages; a 2 % variation isn't that much.
true, but the difference is more pronounced than for other isotopomers
... for a 100 % increase in one of the masses.
The increase in mass shows up in the vibrational frequency, not in the force constant.
I am also a bit surprised by the size of the difference. I'll try to look at the numbers.
Out of curiosity, where are these numbers coming from?
In the harmonic approximation, there should be no difference in the force constants of HCl and DCl. However, adding anharmonic terms changes things. The most straightforward explanation that I can think of is that the zero-point energy for DCl is smaller, so the energy levels sit further down in the well. For a harmonic oscillator, this doesn't make a difference because the force constant is the second derivative of the potential with respect to the coordinate: k = \frac{\partial^2V}{\partial x^2}, which is a constant (obviously) for V=kx^2. However, if the potential is anharmonic (as it is in a real molecule), ##k## is in general not constant, and so lowering the zero-point energy has the effect of changing ##k##. There are probably other higher order effects at play here as well, but the main reason is the anharmonicity of the covalent bond.
Likes Steven Hanna
I've checked the numbers, and these don't make sense. The actual force constant is 2 orders of magnitude smaller, and the relative difference between HCl and DCl is of the order of 4×10-5.
These numbers are from an experimental protocol for my lab report. I can check on the actual references. In the meantime, I'll give another example that I can actually cite. The force constants of H2 (k = 510 N/m) and D2 (k = 527 N/m) differ by ca. 17 N/m. The reference for these numbers is McQuarrie, D. A. Quantum Chemistry, 2 ed.; University Science Books, Mill Valley, CA, 2008, p 221.
I've posted a page from the textbook here: http://imgur.com/TBmpHNT
I'll check my calculations again and will post them here.
k
Sorry to dredge up an old thread, but I'm taking a physorg class and we're talking about isotope effects. So anyway, I understand why the ZPE of DCl is lower than that of HCl, but I'm not quite sure how anharmonicity causes k to not be constant. As I understand it, the series expansion of V(x), where x is the displacement of the bond from equilibrium, is V(x) = ∑(1/n!)(d(n)V/dx)*xn. However, these terms don't depend on the reduced mass. Since you can differentiate taylor series term-by-term, d2V/dx2 should also be independent of reduced mass too, right? Also, the equation for a Morse potential, V(x) = D[1-exp(-ax)]2 doesn't contain any mass terms (a = sqrt(k/2D)).
Steven Hanna said:
k
$$k=\mu \omega^2$$
So the Morse potential does contain mass terms; they're just hidden in the force constant. Ditto for a generic potential, since even in the harmonic case, ##V(x)=\frac{1}{2}\mu \omega^2 x^2##. So for an anharmonic example, if you have ##V=\frac{1}{2}\mu \omega^2 x^2 + \varepsilon x^3##, then your force constant
$$k=\frac{d^2V}{dx^2}$$
will be ##k(x)=\mu \omega^2 + 6\varepsilon x##, both mass-dependent and non-constant.
TeethWhitener said:
$$k=\mu \omega^2$$
OK I think I get it. If I differentiate the Morse equation twice I get
dV/dx = 2D[1-exp(-ax)]*a = 2aD -2aD*exp(-2ax)
dV2/dx2 = 4a2D*exp(-2ax)=4(μω2/2D)D*exp(-2ax) = 4μω2exp[-2x*sqrt(μω2/2D)]
This final result is not simply equal to μω2, contains an additional mu term, and decreases exponentially with x, as does the restoring force of a covalent bond near the dissociation limit. Agree?
Steven Hanna said:
Agree?
Sounds reasonable.
