EstimatedEyes
- 31
A stick of uniform density with mass M = 8.6 kg and length L = 0.7 m is pivoted about an axle which is perpendicular to its length and located 0.24 m from one end. Ignore any friction between the stick and the axle. What is the magnitude of the vertical component of the force exerted by the stick on the axle when the stick passes through the vertical?
I already correctly calculated that the angular velocity when it is in the vertical position is 6.38 rad/s and that the center of mass is .11m below the axis of rotation when it is in the vertical position. From this I calculated v of the center of mass by multiplying the angular velocity to the radius. Once I got this answer I calculated the centripetal force by v^2/r and then added it to mg. This answer is not right, but I don't know where I went wrong. I'm sure it's something really simple. Thanks in advance for your help!
