Calculating Force Exerted in Space: A Problem-Solving Guide
  • Thread starter Thread starter sebas531
    Force
To calculate the force exerted on an astronaut during lift-off from planet Zuton, one must consider both the astronaut's weight on Zuton and the additional force from the spaceship's acceleration. The astronaut's weight on Zuton is derived from their mass, calculated as 798 N divided by Earth's gravity (9.8 m/s²), resulting in a mass of approximately 81.43 kg. This mass, when multiplied by Zuton’s gravity of 8.8 m/s², gives a weight of about 716.58 N. The total force exerted during lift-off includes this weight plus the force from the spaceship's acceleration, which must be factored in using Newton's second law. The discussion highlights the confusion surrounding the integration of gravitational and acceleration forces in the calculations.
sebas531
force exerted... Please help
An astronaut who weighs 798 N on the surface of the Earth lifts off from planet Zuton in space ship. The free fall acceleration on Zuton in 8.8 m/s2. At the moment of lift off the spaceship experiances an acceleration gravity of 8.9 m/s2.
What is the magnitude of the force that the spaceship exerts on the astronaut? Answer in units of N.
Please help me
The question is not stated very well in terms of the extra force from the rocket acceleration, but whatever. Can you tell us how much the person weighed on Zuton before the ship took off? And how much force does the acceleration of takeoff add? What is the total?
Well since the Astronaut's mass is 798 / 9.8 which equals 81.43, shouldn't his weight on Zuton be 81.43 * 8.8 which equals 716.58? Not sure if that helps much :p
I have the same problem as above with slightly different numbers...
The mass of the astronaut ends up being 74.1 in my problem (he weighs 726.6N on Earth)
Gravity on Zuton=7.8m/s2
The ship accelerates at a speed of 9.1m/s
I've tried to plug in numbers in Newton's 2nd law and still can't seem to come up with the correct answer. I figured that gravity and the ships 'a' must be part of the equation at some point but i can't seem to figure out how they fit.
Please help?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
