Force of attraction between proton and electron
The discussion centers on calculating the force of attraction between a proton and an electron in a hydrogen atom, given their separation of 5.00 x 10^-11 m. The relevant formula used is F = kQ1Q2/r^2, where the charges of both the proton and electron are identified as 1.6 x 10^-19 C. Participants clarify that while the proton has a positive charge and the electron has a negative charge, their magnitudes are equal. The constant k is also needed to complete the calculation. Overall, the conversation emphasizes understanding the charges and the application of the formula to find the force.
GRAvit__
What is the force of attraction between a proton and an electron in a hydrogen atom, if they are 5.00 x 10^-11m apart?
F=kQ1Q2/r^2
I really don't know where to go from here since i don't know the charge of the proton or electron. I just started the unit on electricity and am having a hard time with the first exercise sheet
Thanks for any help you can give me
you need to refer to you data book to get the charge on an electron and a proton.
Your equation is correct
Ok i went through it again so is the elementary charge be considered the proton charge = 1.60 x 10^-19 and electrical charge would be 1 C = 6.24 x 10^18?
You have it...the charges are equal and are 1.6 x 10^-19C
The separation (r) = 5 x 10^-11m
You need the constant,k, then you can complete the calculation.
Ok i finally got thanks
Just one thing is confusing me and that is how the proton and the electron have the same electrical charge? I was under the impression they were different or atleast the electron had a (-) ?
Charge is same. For convention we put a negative.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
