Force of Gravity & Coulomb's Law Force Question
The discussion revolves around calculating the charge on two small spheres suspended at an angle due to gravitational and electric forces. The user initially calculated the gravitational force using the sine of the angle and mass, arriving at a value close to the expected charge but not exact. Participants confirm the user's approach, suggesting that the equation mg*sinθ = kq²/r² is correct for balancing forces. There is emphasis on drawing force diagrams to visualize the forces acting on the spheres, including tangential forces. The conversation highlights the importance of accurately representing forces to solve for the charge, ultimately leading to the correct answer of 0.58 μC.
Medeiros
Two small spheres of 15 g each are suspended from a common point by threads of length 35 cm. Each thread makes an angle with the vertical of 20 degrees. Each sphere carries the same charge. Find the magnitude of this charge.
(The correct answer is: 0.58 μC)
1) F= k|q1| |q2| / r2
2) SOH CAH TOA
3) F=ma
I drew a picture of the 2 strings hanging from the same point and labelled the angles.
Knowing that F(g)=max on Y axis and = 0 on X axis,
I thought I could get the force of gravity on the two particles by
angle x g x mass
sin(20) x 9.81 x 0.015 = 0.05033...N
(I also did this another way by finding a vector from how much of the string on the Y axis as missing, and doing a ratio between that and the length of the string, which took a long time and turned out to be sin(20) anyway)
From there, I plugged that force in Eq.1:
q2 = Fr2 / k
so q = 0.56625 μC
Although it is close, I didn't round off anything to get that answer, and my answer still doesn't round off to the correct one.
I was just wondering if
1. Did I get the force the wrong way?
2. Is there an easier way to do it?
2. Is there another way to do this?
Thank you in advance
You seem to be saying mg*sinθ = kq2/r2. Is this correct?
Draw a force diagram. What is the magnitude of the tangential force tending to reduce the angle? What is the magnitude of the tangential force tending to increase the angle?
Likes Medeiros
Yep that is correct.
I THINK I drew the tangential force vectors tending to reduce the angle in my first attempt and made it equal to the force increasing the angle (the electric force) which was the same as sin(20)*g*m
If that's not it, I'm not sure what it is then
Is the electric force tangential?
