Calculating Force on Particle in Spring Setup
  • Thread starter Thread starter AriAstronomer
    Force Spring
A particle attached between two identical springs on a frictionless table experiences a force when pulled perpendicularly. The force exerted by the springs is derived as F = -2kx(1 - x/(sqrt[x^2 + L^2])). The stretched length of the springs is calculated as sqrt(x^2 + L^2), and the horizontal component of the force requires multiplying by x/sqrt(x^2 + L^2), which relates to the cosine of the angle between the displacement and the stretched length. The discussion emphasizes understanding the vector nature of the force and the importance of considering both x and y components. This analysis clarifies the derivation of the force equation in the spring setup.
AriAstronomer
A particle is attached between two identical springs on a
horizontal frictionless table. Both springs have spring
constant k and are initially unstressed. (a) If the particle
is pulled a distance x along a direction perpendicular to
the initial configuration of the springs, as in Figure
P7.66, show that the force exerted on the particle by the
springs is:
I've attached a printed screen that includes Figure P7.66.
So I know new stretched length is sqrt(x^2 + L^2), forces in y direction cancell, x is multiplied by 2.
New stretched length is L' = sqrt(x^2 + L^2) - L.
F = -kx = -2k[sqrt(x^2 + L^2) - L].
Now here's where I get stuck. It seems like to get the right answer, I need to multiply this by a factor of x/sqrt(x^2 + L^2)...why?
Thanks,
Ari
Until now, you have done a good job.
Now, look at the solution. The result is a vector force. It's a component of a red force in my photo, i.e. that is a horizontal component of a spring force.
Alright, I understand that it's only a horizontal component that survives, so is this x/sqrt(x^2 + L^2) like a unit vector thing (vector/length)? If so, what context of the question tells you "oh, I should replace this unit vector with vector/length, instead of keeping it as is..". If this is not a unit vector thing still not sure where this extra term is coming from.
F = -kx = -k[\sqrt{x^{2}+L^{2}} - L]--->Force of one spring
\sqrt{x^{2}+L^{2}}-->stretched length of a spring
\frac{x}{\sqrt{x^{2}+L^{2}}}--->cosine between x and stretched length
-k[\sqrt{x^{2}+L^{2}} - L] * \frac{x}{\sqrt{x^{2}+L^{2}}} i.e.
-kx[\sqrt{x^{2}+L^{2}} - L] * \frac{1}{\sqrt{x^{2}+L^{2}}} --->force of one spring
Ahh, of course. I figured just slapping an i hat on was sufficient. I should have realized it was still involving both x and y until a cosine is taken. Thanks a lot method_man.
