What Is the Magnetic Force on a Current-Carrying Wire in Earth's Field?
The discussion revolves around calculating the magnetic force on a current-carrying wire in Earth's magnetic field. A power line carrying 5000A of current from south to north is analyzed, with Earth's magnetic field at 60.0 microT directed north and inclined at 70 degrees. The formula F = iL x B is used, and there is confusion regarding the angle to use for the calculation. Ultimately, the correct angle is determined to be 20 degrees instead of 70 degrees, resolving the initial confusion. The thread concludes with the participant expressing relief after clarifying the problem.
Andromeda321
For the life of me I can't seem to get the right answer for this problem!
A horizontal power line carries a current of 5000A from south to north. Earth's magnetic field (60.0 microT) is directed toward the north and inclined downward at 70.0 degrees to the horizontal. Find the (a) magnitude and (b) direction of the magnetic force on the 100m of the line due to Earth's field.
So here's what I've been thinking so far: first off you're using F=iLxB here where your L vector's going to point in the j direction. By this point I've sufficiently confused myself to the point where I'm not sure if you need a sin(70) for the j direction or not... hmmmm. I'm pretty confident that I can cross the vectors alright which sort of implies I've messed up somewhere else, I'm thinking maybe my B vector...
Any advice would be appreciated. :smile:
I'm not sure what L and i are, but yes, sin(70) will be useful.
Ah ok, figured out what I was doing wrong (it's supposed to be an angle of 20 degrees instead of 70... *bangs head*). So all's well that ends well.
