Solving Force and Vector Problems: Tips and Examples
  • Thread starter Thread starter elitespart
The discussion focuses on solving force and vector problems, specifically addressing the calculations of force components. One participant calculated force 3 to be 78.1 N at an angle of 146.3 degrees but questioned the accuracy of this result. Concerns were raised about the x-component being incorrectly calculated as -65 N instead of the correct expression involving F2 and F1X. The vertical component was confirmed to be correctly calculated using sine rather than cosine. The conversation emphasizes the importance of accurately determining force components and angles in vector analysis.
elitespart
http://imageshack.us"
http://g.imageshack.us/img10/scan0001px3.jpg/1/"
http://g.imageshack.us/img27/scan0001xe4.jpg/1/"
Well I just set the sum of x and y components equal to 0 and got: force 3 = -65N in x and 43.3N in y which gave me a magnitude of 78.1 N and 146.3 degrees counterclockwise from x-axis. Right? Wrong? Thanks for your help.
Doesn't look right. I checked the vertical part - F1 has 25 N down. F3 should have 25 N up but, according to your answer, has 78.1*cos(146.3-90) = 43N up.
No, I don't think it's entierly correct.. I got my doubts first when it came to your angle - if you mean from the x-axis to the right (if you understand what I mean, I don't know the terminology at the moment), F3 is in the second quadrant, and if it's from the other x-axis, so to speak, it's in the fourth and neither make much sense.
I've been thinking for a while and it's your x-component that's wrong.. It's not supposed to be -65. It's supposed to be F2 - F1X, right? Redo this step.
Edit: Nah, the vertical's correct. The vertical is = F3 * sinθ, not cosθ. (In reply to what Delphi51 said (; )
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
