Forces in a homogeneous electric field
A charged metal ball with a mass of 9.2 grams is suspended between the plates of a capacitor and moves horizontally by 4.3 cm after being charged. The gravitational force acting on the ball is calculated to be 0.0903 N, which corresponds to the vertical component of the tensile force. The main challenges discussed include calculating the angle of displacement and formulating the equation for the electrical force acting on the ball. The solution involves using the length of the wire and the horizontal displacement to establish relationships through similar triangles. The participant finds clarity in applying the concept of similar triangles to solve the problem.
tomkoolen
Hello everyone,
I was wondering if anyone could help me out with this one:
Problem statement:
A charged metal ball is hanging from a nylon wire in the space between both plates of a loaded capacitor. The ball has a mass of 9.2 grams. The distance between the hanging point and the ball's centre of mass equals 71.7 cm. After the ball has been charged, it horizontally moves 4.3 cm. See this illustration for the forces working on the ball:
Calculate the electrical force working on the ball.
My attempt at solution:
The gravitational force equals 0.0903 N which is equal to the vertical component of the tensile force. I'm actually already stuck right now because of the following problems:
1. I don't see how to calculate the angle α because I only have one side of the triangle.
2. I don't know how to write an equation for Fel because the presence of a nett force doesn't allow me to set it equal to the horizontal component of the tensile force.
Thank you very much in advance!
1. You have two sides; the length of the wire and the horizontal displacement.
2. Think about similar triangles and ratios.
Likes 1 person
Thank you for your reponse! I see how to work it out with similar triangles now :)
