Forces on systems in equilibrium
To find the mass of the beam in a system involving a pulley and pivot, it is essential to start by labeling all forces acting on the system, including tensions in the strings and gravitational forces. Since the system is in equilibrium, the net force must equal zero, indicating that all forces will balance out. This equilibrium condition allows for the establishment of relationships between the various forces involved. Understanding the role of torque is also crucial, as it relates to the rotational aspects of the system. By analyzing these forces and their relationships, one can derive the necessary equations to solve for the mass of the beam.
ebola_virus
set up two retort stands to support a pulley and a pivot and arrange the apparatus as shown in the diagram attached... and I'm kinda stuck as to how to find the mass of the beam in this instance?
Could you give me any starting references i can work along with; torque is involved, but i just don't undersatnd because I was thinking that the involvement of the pulley is quite important?
The first step in a problem like this is always: draw a diagram (done), and label all the forces with vectors [arrows].
So label the forces first (tensions on strings, forces of gravity, etc). Then, we know the system is in equilibrium, which means the net force is zero. That is, all the forces will cancel each other out.
This allows you to start writing relationships between the variuos forces.
