Forces with friction problem, two block on each other
The discussion focuses on a physics problem involving two blocks with friction on a frictionless table. The key points include the application of Newton's Laws and the need to balance forces acting on both blocks, specifically the applied force, tension, and friction. Confusion arises regarding the direction of tension and friction forces, with participants clarifying that the friction on the top block acts to the right while tension acts to the left. It is emphasized that the forces must be analyzed separately for each block to correctly set up the equations. Overall, the conversation highlights the importance of understanding force interactions in a system with friction.
Asphyxiated
The original problem with statement is http://images3a.snapfish.com/232323232%7Ffp733%3B9%3Enu%3D52%3A%3A%3E379%3E256%3EWSNRCG%3D335%3A728%3A%3B4347nu0mrj".
Newton's Laws 1-3
Note that the table is frictionless, the only friction is between the two boxes
So first:
\mu = .45
and the T on M1 is
T_{m_{1}}=F_{a}
and T on M2 is
T_{m_{2}}=-F_{a}
and
F_{n_{1}}=m_{1}g
F_{n_{2}}=m_{1}g+m_{2}g
So the friction force on M1 from M2 should be:
F_{ \mu_{1}} = \mu F_{n_{1}}
and the friction on M2 from M1 should be:
F_{ \mu_{2}}=\mu F_{n_{1}}
So i am kind of confused as to how I should use the T forces... here is what I did:
F_{net_{x}} = F_{a}+F_{\mu_{1}-T-F_{\mu_{2}}=0
F_{net_{y}}=F_{n_{1}}+F_{n_{2}}-m_{1}g-m_{2}g=0
is that right? I am not sure how to set up T because for m1 t is opposite the friction force and for m2 T is opposite the Fa force... should I set up a relationship that way to do this correctly?
It seems to me that Fa ≠ T. After all, the horizontal forces on block 1 must balance, and according to the FBD that YOU drew for it (which looks correct), there are three such forces. Fa is to the right and BOTH T and the frictional force from block 2 are pointing to the left.
Yes,horizontal forces on block 1 should balance.If T is the tension in the string acting to pull the body to left then the frictional force between the bodies will act to the right to counter the tension.So T=f.
Now coming to the second block it has got F acting to the right and tension acting to the left.Since the frictional force is acting to right on block 1,it acts to left on block 2.To sum up the whole thing,your F acts to counter both T(=f) and f.So F equals 2f.Any way i am not sure of this.:biggrin:
Yeah, but you're forgetting the applied force (also points to the right). EDIT: and you also haven't specified which frictional force you're referring to. The one that acts on block 1 points to the left, in the SAME direction as the tension. I explicitly said that there were THREE horizontal forces acting on block 1 in my previous post. Let's let the OP take stock of things...
Block 1 is the top one and block 2 is bottom one right?Force acting on the bottom block cannot directly act on the top one.The only way for it is to use friction.Now if the friction tries to stop the relative motion it should act to right on the top block since it tends to move to left.
do not write vertical and horizontal equations for whole system that is unnecessary
just balance vertical and horizontal forces on each block.
Remember the tension in the string is uniform
Hey -- I was referring to the bottom block as "block 1" without double-checking the labeling on the picture. Sorry.
