Forward difference operator [SOLVED] Forward difference operator
foxjwill
I was looking on Wikipedia and noticed that it said that \Delta_h could be written as
<br /> \begin{align*}<br /> \Delta_h &amp;= \sum_{n=0}^\infty \frac{(hD)^n}{n!}\\<br /> &amp;= e^{hD} - 1<br /> \end{align*}<br />
where D is just the standard derivative. What I don't understand is how they came up with the infinite series.
Try applying it to a function.
Ok, so I tried going at it this way:
<br /> \begin{align}<br /> f(x+h) &amp;= f(h) + (x+h)Df(h)+ \dfrac{(x+h)^2 D^2 f(h)}{2!} + \cdots\\<br /> f(x) &amp;= f(0) + xDf(0) + \dfrac{x^2 D^2 f(0)}{2!} + \cdots<br /> \end{align}<br />
However, when I try subtracting (2) from (1), the terms don't cancel out because (1) is in terms of f(h) and (2) is in terms of f(0). What should I do?
Trying to express \Delta_h f(x) in terms of \Delta_h f(0) seems like an odd thing to do; I'm sure there's an interesting result to be derived, but I don't see why it would relate to the question you're trying to solve.
Incidentally, your Taylor series in (1) is incorrect.
Hurkyl said:
Trying to express \Delta_h f(x) in terms of f(0) and f(h) seems like an odd thing to do...
I was using the tailor series expansion. Do you have any other ideas?
I've added more to my previous post.
I don't have any new ideas; what's wrong with the one I already gave?
As Hurkyl said, the Taylor series expansion for the first one is wrong.
The Taylor series for f(x), expanded around x= a, is
f(a)+ f&#039;(a)(x-a)+ f&quot;(a)/2 (x-a)^2+ /cdot/cdot/cdot+ f^{(n)}(a)(x- a)^n+ \cdot\cdot\cdot
If you are expanding f(x+h) about x= h, then it would be
f(h)+ f&#039;(a)((x+h)-h)+ f&quot;(h)/2 ((x+h)-h)^2+ /cdot/cdot/cdot+ f^{(n)}(h)((x+h)- h)^n+ /dot/cdot/cdot
= f(h)+ f&amp;#039;(a)(x)+ f&amp;quot;(a)/2 x^2+ /cdot/cdot/cdot+ f^{(n)}(h)x^n\cdot\cdot\cdot<br /> <br /> If you are expanding f(x+h) about x= 0, then it would be<br /> f(0+ f&amp;#039;(0)(x+h)+ f&amp;quot;(0)/2 (x+y)^2+ /cdot/cdot/cdot+ f^{(n)}(0)(x+y)^n+ \cdot\cdot\cdot
What's the wikipedia url for that result? :confused:
Ok, so I fixed your \LaTeX:
f(a) + f&#039;(a)(x-a) + \frac{f&#039;&#039;(a)}{2}(x-a)^2 + \cdots + f^{(n)}(a)(x-a)^n + \cdots
f(h) + f&#039;(a)((x+h)-h) + \frac{f&#039;&#039;(h)}{2} ((x+h)-h)^2 + \cdots + f^{(n)}(h) ((x+h)-h)^n + \cdots
= f(h) + f&#039;(a)(x) + \frac{f&#039;&#039;(a)}{2} x^2 + \cdots + f^{(n)}(h) x^n + \cdots
f(0) + f&#039;(0)(x+h) + \frac{f&#039;&#039;(0)}{2}(x+y)^2 + \cdots + f^{(n)}(0)(x+y)^n + \cdots
I'm not really sure how you got the expansions to be those. Could you explain?
\Delta_h(f(x))=f(x+h)-f(x)\Rightarrow \Delta_h(f(x))=\left(T_h-I\right)\,f(x)\quad \text{with} \quad T_h f(x)=f(x+h)
Expanding f(x+h) around \alpha=h we have
f(x+h)=f(h)+\frac{1}{1!}\,f&#039;(h)\,x+\frac{1}{2!}\,f&#039;&#039;(h)\,x^2+\dots+\frac{1}{n!}\,f^{(n)}(h)\,x^n+\dots\Rightarrow f(x+h)=\sum_{n=0}^\infty\frac{x^n}{n!}\,f^{(n)}(h)\Rightarrow f(x+h)=\sum_{n=0}^\infty\frac{h^n}{n!}\,f^{(n)}(x)
where at the last equality I changed the roles of x,\,h since they are just labels. This equality can be written as
f(x+h)=\left(\sum_{n=0}^\infty\frac{(h\,D)^n}{n!}\right)\,f(x)
and from here you have the desired result.
