Fourier series - DC component, integration problem
DrOnline
Find the Fourier series representation of:
f(t)={-t , -∏<t<0
f(t)={0 , 0<t<∏
This is a piecewise function.
T=2∏ (the period)
a_{0}=\frac{2}{T}*\int_0^T f(t),dt
I need help only with calculating the DC component. Once I get that working, I can continue on my own. Tried multiple times, I keep getting pi/2.
The correct answer should be pi/4.
This is my graph:
Is this graph correct?
I consider the area of the function from -pi to 0 identical if I change it from:
f(t)=-t -∏<t<0
to
f(t)=t 0<t<∏
Is this permitted? Surely it's the same result. Seems alright to me
a_{0}=\frac{2}{2\pi}*\int_0^∏ -t,dt
a_{0}=\frac{1}{\pi}*(\frac{\pi^2}{2}-0)
a_{0}=\frac{\pi}{2}
And the book says it should be pi/4.
What am I doing wrong? Is my graph correct? Is my integration correct? Is the book's solution wrong?
I think I figured it out... my a0 seems correct to be ∏/2,
but when I type out the actual Fourier series, the formula is:
a0/2, making it ∏/4.
If anybody wants to confirm my thinking, that would be helpful!
Textbooks are not consistent on the formula for ##a_0## because some formulas assume the constant term in the series is ##a_0## and some use ##\frac {a_0} 2##, which causes the formula for ##a_0## to differ by ##2##. As long as you are consistent, you should be OK. But there is no need to go to a different interval than that where the function is given. If the constant term of the series is ##a_0## and the period is ##2p## then$$
a_0 = \frac 1 {2p}\int_{-p}^p f(t)\, dt = \frac 1 {2\pi}\left(\int_{-\pi}^0 -t\, dt
+\int_{-\pi}^0 0\, dt\right) = \frac \pi 4$$
Thank you for helping me with this!
I think perhaps an error has snuck into your maths though, because you write:
a_{0}=\frac{1}{2p}...=\frac{1}{2\pi}...
But p=2∏, so it should be a_{0}=\frac{1}{4\pi} using your formula.
Can you comment on this?
I understand how there are different formulas though, as you say, when I created the question I hadn't realized that I had to divide it by 2 again, but when I did I wanted somebody to confirm my logic.
I also understand, of course, that I don't have to tinker with the range and function, but that saved me having to deal with negative values etc, I should stick with the actual function though, I have to be at a level where that kind of thing doesn't phase me.
No, I said the period was ##2p## so ##p=\pi## in your case. And when you do the integral you will have a ##t^2## in the numerator with a limit of ##-\pi## which will give a ##\pi^2## in the numerator.
Yes of course, I was too quick in reading there, thanks again!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
