Fourier series - trig and complex not matching?
haydez98
fourier series - trig and complex not matching?
i am given a signal which can be written as:
s(t) = -1 {-1 < t < 0}, 1 {0 < t < 1}, 0 {1 < t < 2} [it's a pulse train]
the period, T, is 3.
i have calculated the trig. Fourier series representation, which in MATLAB turns out to be correct, yet when i calculate the exponentical fsr, i get a version of the trig. fsr which has its amplitude halved.
for the trig fsr:
s(t) = 2/(pi * n) * (1 - cos((2 * pi * n)/3)) * sin((2 * pi * n * t)/3);
for the exp fsr:
s(t) = -1/(i * pi * n) * (cos((2 * pi * n)/3) - 1) * exp((i * 2 * pi * n * t)/3)
i also tried
c_n = 0.5 (a_n - i * b_n) = -0.5 * i * ( 2/(pi * n) * (1 - cos((2 * pi * n)/3))
either case, my complex fsr was a scaled amplitude version of my trig fsr...when i get rid of the 0.5 it turns out to be right, but why would i get rid of the 0.5?
thanks in advance
Hint:
\sin x = \frac{e^x - e^{-x}}{2 i}
okay i'll show you my working out...
<br /> c_{n}=\frac{1}{T}\int_{0}^{T}s(t)e^{\frac{-j2\pi nt}{T}}dt
=\frac{1}{T}\left [\int_{-T/3}^{0}-1e^{\frac{-j2\pi nt}{T}}dt + \int_{0}^{T/3}1e^{\frac{-j2\pi nt}{T}}dt \right ]
=\frac{1}{T} \left[\left[\frac{T}{j2\pi n}e^{\frac{-j2\pi nt}{T}} \right]_{-T/3}^{0} +\left[\frac{-T}{j2\pi n}e^{\frac{-j2\pi nt}{T}} \right]_{0}^{T/3}\right]
=\frac{1}{j2\pi n}\left[1 - e^{\frac{j2\pi n}{3}}+e^{\frac{-j2\pi n}{3}}+1\right]
=\frac{1}{j2\pi n}\left[2-2cos(\frac{2\pi n}{3})\right]
=\frac{1}{j\pi n}\left[1-cos(\frac{2 \pi n}{3})\right]<br />
(note: i used the cosine identity)
Therefore:
<br /> s(t)= \frac{1}{j\pi n}(1-cos(\frac{2 \pi n}{3}))e^{\frac{j\pi nt}{3}}<br />
However, when I put this into matlab, it doesn't satisfy the trig fsr.
Almost everything looks fine. Except, well, you still got to sum over n... ;)
So:
s(t) = \sum_{n=-\infty,\neq 0}^{\infty} c_n e^{j\pi n t / 3}
where
c_n = \frac{1}{j\pi n}(1-\cos \frac{2\pi n}{3})
Note also that c_0 is left out (in other words, c_0=0, do you see why?)
Now we see that
c_{-n} = -c_n
so the sum can be rewritten as:
s(t) = \sum_{n=1}^{\infty} c_n e^{j\pi n t / 3}+c_{-n}e^{-j\pi n t / 3}<br /> = \sum_{n=1}^{\infty} c_n e^{j\pi n t / 3}-c_{n}e^{-j\pi n t / 3}<br /> =\sum_{n=1}^{\infty} c_n \left(e^{j\pi n t / 3}-e^{-j\pi n t / 3}\right)<br /> =\sum_{n=1}^{\infty} 2i c_n\sin{j\pi n t / 3}
Which is the trig fsr.
ah coolness. i didn't know about having to put c_-n in it too
thanks so much
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
