Fourier Transform: Decompose Vector Function
LocationX
For some reason I can't post everything at once... gives me a "Database error" so I will post in parts...
A vector function can be decomposed to form a curl free and divergence
free parts:
\vec{f}(\vec{r})=\vec{f_{\parallel}}(\vec{r'})+\vec{f_{\perp}}(\vec{r'})
where
\vec{f_{\parallel}}(\vec{r'}) = - \vec{\nabla} \left( \frac{1}{4 \pi} \int d^3 r' \frac{\vec{\nabla'} \cdot \vec{f}(\vec{r'})}{|\vec{r}-\vec{r'}|} \right)
and
\vec{f_{\perp}}(\vec{r'}) = \vec{\nabla} \times \left( \frac{1}{4 \pi} \int d^3 r' \frac{\vec{\nabla'} \times \vec{f}(\vev{r'})}{|\vec{r}-\vec{r'}|} \right)
I am trying to take the Fourier transform of \vec{f_{\parallel}}(\vec{r'}) and \vec{f_{\perp}}(\vec{r})I am starting at \vec{f_{\parallel}}(\vec{r'}). We know that the Fourier transform is given by:
\vec{f}(\vec{k}) = \int_{-\infty}^{\infty} d^3r e^{- i \vec{k} \cdot \vec{r}} \vec{f}(\vec{r})
\vec{f}(\vec{r}) = \frac{1}{(2 \pi)^3} \int_{-\infty}^{\infty} d^3k e^{- i \vec{k} \cdot \vec{r}} \vec{f}(\vec{k})
I'm not exactly sure where to begin. If I just plug and chug , we'd have:
\vec{f}(\vec{k}) = \int_{-\infty}^{\infty} e^{- i \vec{k} \cdot \vec{r}} - \vec{\nabla} \left( \frac{1}{4 \pi} \int \frac{\vec{\nabla'} \cdot \vec{f}(\vec{r'})}{|\vec{r}-\vec{r'}|} d^3 r' \right) d^3rI just do not see a simple way of tacking this problem. Any thoughts would be appreciated.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
