Fraction of energy dissipated when solid cylinder placed on table
A uniform solid cylinder spinning about its axis experiences energy dissipation due to sliding friction when placed on a rough horizontal table. The initial kinetic energy can be expressed using the equations 0.5mv^2 for translational motion and 0.5Iw^2 for rotational motion. As the cylinder transitions from sliding to rolling, a portion of its initial kinetic energy is lost to friction. The discussion concludes that the fraction of kinetic energy dissipated before the cylinder rolls smoothly is 2/3. This problem highlights the importance of conservation of angular momentum at the point of contact during the transition.
looli9
A uniform solid cylinder is set spinning about its axis and is then gently placed, with the axis horizontal, on a rough horizontal table. What fraction of its initial kinetic energy is dissipated in sliding friction before the cylinder eventually rolls smoothly along the plane?
The only equations I think are needed are 0.5mv^2 and 0.5Iw^2, and I can write down equations for the total energy before and after, but cannot relate the two.
Apparently the answer is 2/3.
Thanks
Think conservation of angular momentum with respect to the point of contact.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
