Is the Fracture Energy Equation for Ice Valid?
  • Thread starter Thread starter lewisd18
    Energy Fracture
The discussion centers on the validity of using the equation for fracture energy of ice, expressed as potential energy divided by cross-sectional area. Participants confirm that this approach is rational, as it yields units of J/m², indicating energy per unit area. The equation is deemed appropriate for calculating the fracture energy after applying weights until the ice breaks. The consensus supports the method's applicability in a homework context. Overall, the equation for fracture energy in ice is considered valid based on the provided reasoning.
lewisd18
i have been told i can use the equation potential energy/cross sectional area to work out fracture energy of ice after dropping weights on it till it breaks. is this true?
fracture energy = potential energy/cross sectional area
as above
It seems rational: as the units you would be given are Jm^{-2} which would imply the energy per unit area.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
