Solving for Cliff Height: An Alert Hiker's Task
  • Thread starter Thread starter black_hole
    Height
An alert hiker observes a boulder falling from a cliff, noting it takes 1.3 seconds to fall the last third of the distance. The problem requires calculating the cliff's height while ignoring air resistance. The relevant equations for vertical motion include y = yo + vit + 0.5gt^2, with initial velocity (Vi) set to zero and final velocity (Vf) at impact. The discussion highlights the importance of determining both potential solutions for height, with one possibly being extraneous. The calculations aim to provide a clear understanding of the cliff's height based on the observed fall time.
black_hole
An alert hiker sees a boulder fall from the top of a distant cliff and notes that it takes 1.3s for the boulder to fall the last 3rd of the way to the ground. Ignore air resistance.a) what is the height of the cliff in meters? b) If in part a) you get 2 solutions what does the extraneous one represent?
looking at the last 3rd
Vi = ?
Vf = 0 m/s
a = -9.8 m/s/s
t = 1.3s
x = ?
possibly going to use this equation: x = xo +vit +.5at^2 ?
you should use the equation y = yo +vit +.5gt^2 for vertical motion.
also Vi should equal zero, as the boulder begins from rest in the y-axis and Vf should equal the final velocity as the boulder hits the ground
