Building a Free Standing Structure with KOH Etching | Expert Tips
  • Thread starter mocaliber
  • Tags
    Structure
In summary, the conversation revolves around etching techniques for creating a free-standing structure. There is confusion about using KOH as an etchant for SiO2 and the limitations of this process. It is mentioned that Si or Si3N4 can be used as a mask material for this type of structure. The difficulty of deep etching SiO2 is also discussed.
mocaliber
Hi,
Though this may be a basic technique, I would like to know how to make a free standing structure.
Most of the papers use KOH as etchant to etch SiO2 and then get such structure.
And I think besides putting SiO2 into the etchant, there should be some other things work with this fabrication. Coating the photo resist? I am not sure..
So, it would be a great help if anyone can help me solve this stupid question.
Thank you!
KOH is used to etch Si, SiO2 or Si3N4 is often used as a mask material. Not sure what you want as a free standing structure. If you wanted a cantilever structure in KOH than the correct mask can achieve this.
If you want to undercut a Si structure by etching SiO2 bellow you want to use HF or a more controllable BOE (buffered HF). If you where using SOI (silicon on insulator) chips than BOE/HF is the way to go.
What wafers are you using?
oh, sorry for my ambiguous description! The free-standing structure I meant is like this picture.
My problem is that how can I get such structure with KOH as etchant. And my wafer is SiO2.
Thanks for your reply!
If your wafer is SiO2 you CAN NOT accomplish that etch with KOH. In theory you could with BOE, but deep wet etches in SiO2 present many problems and there is not a 111 plan to etch at a sharp angle as with KOH. BOE would leave rounded edges, would under cut your mask and it is difficult to keep a mask on SiO2 while under long term BOE etches.
If you want the structure you posted from a KOH etch, the green material must be Si not SiO2. The gold material should be SiO2 or Si3N4. Remember, deep etching of SiO2 is a very hard problem, one I have been working out for months, KOH etching Si is pretty standard.
Just wanted to second OhulahanBass's comments. KOH etches certain crystalline planes faster than others in Si, but amorphous SiO2 has no crystalline planes, so it would be impossible to get that characteristic pyramidal shape.
What is a free standing structure?
A free standing structure is a building or other construction that is not attached to any other structures or supports. It is designed to support itself and stand independently.
What are the advantages of free standing structures?
One advantage of free standing structures is their versatility. They can be built in a variety of locations and do not require any existing structures or supports. They also provide more design freedom and can be easily modified or expanded.
What materials are commonly used in free standing structures?
The materials used in free standing structures vary depending on the purpose and design of the structure. Some common materials include wood, steel, concrete, and brick. The choice of material often depends on factors such as cost, durability, and aesthetic preferences.
How are free standing structures designed and built?
The design and construction process for free standing structures involves several steps. First, the specific needs and purpose of the structure are identified. Then, a design is created and approved, followed by obtaining necessary permits and approvals. Finally, the structure is built according to the design plans using appropriate materials and techniques.
What are some examples of free standing structures?
There are many types of free standing structures, including houses, office buildings, barns, and even outdoor structures such as gazebos and pergolas. Other examples include towers, monuments, and sculptures.
  • Materials and Chemical Engineering
  • STEM Academic Advising
  • Mechanical Engineering
  • Electrical Engineering
  • Other Physics Topics
  • General Engineering
9K
