Explaining Freefall Questions: Velocity, Displacement & Distance
  • Thread starter bluejade
  • Tags
    Freefall
In summary, two balls with the same initial velocity, but one thrown up and one thrown down, will hit the ground at the same time due to the same acceleration due to gravity. They will also have the same displacement and the ball thrown up will travel a greater distance. The final velocities of both balls upon impact will be the same, and they will have traveled the same distance. The ball thrown up will take more time to reach the ground due to its greater distance traveled.
bluejade
If one ball was thrown down with an initial velocity and another ball was thrown up with the same initial velocity. a) Which would have greater speed when it reaches the ground? b)Which has a greater displacement? c) Which ball will hit the ground first? d) Which traveled a greater distance?
I think they would hit the ground at the same time since they have the same acceleration due to gravity. I'm not sure but I think they have the same displacement and the ball that was thrown up has a greater distance travelled.
Can someone please explain each of these questions?
Where are the balls thrown from? Using conservation of energy will be much easier than using the kinematic equations (if you aren't already using it).
If you stand on a roof and throw one ball down and the other ball up at the same time, would you expect both balls to hit the ground at the same time?
Lets say you throw a ball up with a speed of v0. It goes up and up until it reaches a maximum where v=0. It then begins to fall down again until it reaches the point where you threw it in the air. What is the balls speed at that point?
They are both thrown from the same height
The balls both have the same acceleration, but their initial velocity is different. One has a velocity of +v, and the other, a velocity of -v.
Look at the kinematic equations for both of them, and you'll see that they move in different ways.
As for their velocities upon impact, conservation of energy is a good tool for solving that question.
Draw an illustration of their initial conditions, and their final conditions (The point they were thrown at, and the point of impact with the floor) and look at the expressions for their energies.
Here's a hint: They both have the same initial energy, ½mv², since (-v)²=(+v)²
You can answer all of these problems conceptually.
Think about a simple projectile motion trajectory and consider the initial height to be at the ground. When the projectile hits the ground, how does its speed at the instant of impact compare to its initial speed?
What is the definition of displacement? What is the definition of distance? How do they compare?
I don't really think there is any need to get into all of the projectile motion stuff, you can simply do it by using the equations of motion only.
To figure out which one falls with a greater final velocity, you could simply use the equations of motion. Use v^2 = u^2 - 2gs (we'll take gravity as negative, and, 'v' as zero, because, the ball moves upward), and figure out the distance traveled by the ball in the up direction. After that, use your result, in the same equation (v^2 = u^2 - 2gs) for finding the final velocity in the downward direction (this time, take 'u' as zero).
Once you find the final velocity of the ball that was thrown upward, find the final velocity of the ball that was thrown downward. Both the final velocity will turn out to be the same: sqrt(u^2 + 2gh).
Obviously, both will have an equal displacement, as, both started at the height of the roof of the building and ended up on the ground.
Obviously, the ball thrown upwards will take more time, because it traveled more distance (first it move up, then it traveled on the same path as the other ball).
Related to Explaining Freefall Questions: Velocity, Displacement & Distance
1. What is freefall?
Freefall is a term used to describe the motion of an object falling under the sole influence of gravity. This means that there are no other forces acting on the object, causing it to accelerate at a constant rate towards the ground.
2. How is velocity related to freefall?
Velocity is a measure of an object's speed and direction. In freefall, velocity is constantly changing as the object accelerates towards the ground. Initially, the velocity is zero when the object is dropped, but it increases at a constant rate (9.8 m/s^2) as it falls.
3. What is displacement in freefall?
Displacement is the distance and direction an object has moved from its starting point. In freefall, displacement is affected by both the initial height from which the object is dropped and the acceleration due to gravity. The displacement increases as the object falls, and it is zero when the object reaches the ground.
4. How is distance different from displacement in freefall?
Distance is a measure of how far an object has traveled, regardless of its starting point or direction. In freefall, the distance traveled is continuously increasing as the object falls towards the ground. Unlike displacement, distance takes into account the actual path of the object, rather than just its starting and ending points.
5. Is there a formula for calculating freefall velocity, displacement, and distance?
Yes, there are several equations that can be used to calculate freefall velocity, displacement, and distance. The most commonly used equation is d = 1/2 * gt^2, where d is the displacement, g is the acceleration due to gravity, and t is the time the object has been falling. Other equations, such as v = gt and d = vt - 1/2 * gt^2, can also be used to calculate these values.
