Calculate Horn Frequency Decay Time in Seconds
  • Thread starter 05holtel
  • Tags
    Frequency
In summary, the car accelerating at 0.64 m/s2 and blowing its horn of frequency 451 Hz will take approximately 28.0 seconds for the frequency heard by the observer to decrease by 5%. This takes into account the time it takes for sound to travel the distance the car has traveled in that time period.
05holtel
52
While blowing its horn of frequency 451 Hz, a car accelerates at 0.64 m/s2.
The car starts from rest by your side and moves away.
How long will it take for the frequency you hear to decrease by 5%?
Hint: Do not forget to include the time it will take for sound to reach you.
Give your answer in s, and to three significant figures.
Only answer in numerical values, no units.
speed of sound in air is 340 m/s
fsource = fo (1/(1+vsource/c))
0.95 = (1/(1+vsource/c))
vsourve = 17.89m/s
V= v0 +at
t= 17.89/0.64
t = 28.0 seconds
This is wrong
You probably just need to take into account the time it takes for sound to reach the observer. If the time you got is right, then at 28.0s the car would have traveled some distance that sound would have to cover in some time to get to the observer.
OK. I am not sure how to account for this. What equation would i use?
Thanks alot
The car traveled a distance x = .5at2 from the observer, in which t = 28.0s. This would mean that for the sound carrying the relative frequency to get to the observer, it would have to travel through this distance to get to the observer. Your total time would take this into account.
Related to Calculate Horn Frequency Decay Time in Seconds
1. What is Horn Frequency Decay Time?
Horn Frequency Decay Time is a measure of how quickly sound waves decrease in amplitude within a horn speaker. It is an important factor in determining the sound quality and clarity of a speaker system.
2. How is Horn Frequency Decay Time calculated?
Horn Frequency Decay Time is calculated by measuring the time it takes for sound waves to decrease in amplitude by 60 decibels (dB) from their peak level. This is typically done by using a sound level meter and recording the sound output of the horn speaker.
3. Why is Horn Frequency Decay Time important?
Horn Frequency Decay Time is important because it can affect the overall sound quality of a speaker system. A longer decay time can result in a muddier and less defined sound, while a shorter decay time can result in a clearer and more defined sound.
4. What factors can affect Horn Frequency Decay Time?
Several factors can affect Horn Frequency Decay Time, including the design and size of the horn speaker, the materials used in the construction of the speaker, and the environment in which the speaker is being used.
5. How can Horn Frequency Decay Time be improved?
Horn Frequency Decay Time can be improved by using high-quality materials in the construction of the speaker, designing the speaker with an appropriate size and shape for the intended sound output, and optimizing the placement and environment of the speaker to reduce unwanted reflections and echoes.
