Frequency of light to eject electrons from gold
To eject electrons from a gold surface with a maximum kinetic energy of 6.48×10(−19) J, the frequency of light must be calculated based on the work function of gold, which is 4.58 eV. The energy of a photon is related to its frequency, and the total energy required is the sum of the work function and the kinetic energy. Converting the work function from eV to joules is necessary for accurate calculations. The correct approach involves using the formula for maximum kinetic energy to solve for frequency. The discussion highlights the importance of understanding energy conversions in photon interactions with metals.
mhooker_10
What frequency of light must be used to eject electrons from a gold surface with a maximum kinetic energy of 6.48×10(−19)J ?
The work function of gold is 4.58 eV.
f=
You have to at least attempt an answer to a homework question.
Whats the energy of a photon, in terms of frequency?
I used the formula for K(max) and solved for f and got 6.91 x 10(33)...and that not the right answer
So you need to supply enough energy to overcomethe work function and then supply the KE.
So convert the work function into joules and add to the ke.
Then you just need the energy of aphoton in terms of frequency.
oops - you didn't post in the HW forum, so didn't get the list of things to do.
Nevermind...I figured it out
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
