What is the frequency of light with a wavelength of 7.245×10−7 m in glass?
The discussion revolves around calculating the frequency of light with a wavelength of 7.245×10−7 m in glass, given its index of refraction. The index of refraction for this wavelength is noted as 1.44. A participant calculated the frequency to be 5.03125e-7 Hz but expressed confusion about the accuracy of this result. Another participant requested the original calculation to verify its correctness. The conversation highlights the importance of ensuring calculations align with the physics principles involved.
elitepro
The glass prism has an index of refraction
that depends on the wavelength of the light
that enters it. The index of refraction is
1.44 for light of wavelength 7.245 × 10−7 m
in a vacuum and 1.79 for light of wavelength
4.433 × 10−7 m in vacuum. A beam of white
light is incident from the left, perpendicular
to the first surface, as shown in the figure,
and is dispersed by the prism into its spectral
components.
Determine the frequency of the 7.245×10−7 m
light in the glass.
Answer in units of Hz
c = λf
Alright so I calculated the frequency to be 5.03125e-7 (this is correct),
so I just plugged this into the formula 3*10^8/5.03125e-7 and got 5.96*10^14 m
I thought I did this correctly. Did I do something silly?
I don't see how it can be. How do you know it is right? Please post your calculation.
