Friction of an object on a moving board
  • Thread starter Thread starter grusini
    Board Friction
The problem involves a body placed on a moving board, where the forces acting on both the body and the board are analyzed. The scenario includes a mass for the body and board, a friction coefficient, and an applied force, leading to questions about the motion of the body relative to the board.
  • Participants discuss applying Newton's laws to both the body and the board separately, questioning the forces acting on each. There are attempts to set up equations of motion for both the board and the body, with some participants suggesting the need to consider horizontal forces specifically.
The discussion is ongoing, with participants exploring the relationships between the forces acting on the body and the board. Some guidance has been offered regarding the application of Newton's laws and the importance of considering the friction force. Multiple interpretations of the forces involved are being examined.
Participants are working under the constraints of a homework problem, which may limit the information available for analysis. There is an emphasis on not treating the board and body as a single system due to their relative motion.
grusini
A body of mass [itex]m_A=2 kg[/itex] is placed on a long board of mass [itex]m_B=8 kg[/itex] at distance [itex]d=1 m[/itex] from the rear edge of the board. The friction coefficient between the body and the board is [itex]μ=0.2[/itex]. A force of magnitude [itex]30 N[/itex] is applied to the front edge of the board and the body start moving towards the rear edge. How much time will it take to fall off the board?
The force of friction is given by [itex]F_f=F_n\cdot μ[/itex] where F_n is the normal force exerted by the object on the surface.
I tried to write down Newton's equation of motion (on the x-axis) for the body and the board as follows:
Board: [itex]F=(m_A+m_B)a_1[/itex]
Body: [itex]F\frac{m_A}{m_A+m_B}-F_f=m_A a_2[/itex] where [itex]F_f=m_Agμ[/itex].
With these equations the problems doesn't come out right...
What forces act on the body? Apply Newton's 2nd law.
What forces act on the board? Apply Newton's 2nd law.
(Don't treat 'board + body' as a single system, since parts are in relative motion.)
On the board: [itex]F[/itex] (and the weight of [itex]A[/itex] which is equilibrated by the board itself).
On the body: The force exerted by the board on the body, directed along the direction of [itex]F[/itex] and of a "certain" magnitude and the friction force.
All we care about are the horizontal forces, since vertical forces will cancel.
You are missing the horizontal force of the body on the board. (Newton's 3rd law.)
The only horizontal force on the body is the friction force from the board.
So the body exerts a horizontal force [itex]F_f[/itex] on the board in the opposite direction of [itex]F[/itex]? Then Newton's 2nd law for the board is
[itex]F-F_f=m_Ba_1[/itex]
and the Newton's law for the body would be:
[itex]F_f=m_Aa_2[/itex]?
Right. And you also know how to calculate the friction force.
  • · Replies 33 ·
  • · Replies 24 ·
  • · Replies 16 ·
