Can Friction Cause Torque & Work on Rolling Objects?
Kinetic friction can indeed cause torque and result in rotation if its line of action does not pass through the center of mass. Static friction can also do work on a rolling object, particularly when the object is sliding and rolling simultaneously. The increase in rotational kinetic energy indicates that static friction can contribute to this process. However, it is important to distinguish between static and kinetic friction, as the latter applies when an object is sliding while rolling. Understanding the role of friction is crucial in analyzing torque and work in rolling objects.
kolua
can kinetic friction cause a torque? (can it result in rotation)
Or is it that only static friction can cause a torque?
Can static friction do work on a rolling object?
I think it can? because the rotational kinetic energy is increasing? is this right?
HELP!
First question response: Ask your self "what is the result of friction?" and "what does it take to create torque?" and you should see the answer to your question.
Second question response: The answer to the first question should let you know if the second statement is true.
Yes it can: if the line of action of the friction force doesn't go through the center of mass, then that force represents a torque.
HELP!
Yes it can: if the object is sliding and rolling you can have what you describe. So in exercises the term "rolling without sliding" may appear to exclude that.
[edit]JBA was faster !
Your are right in both of your answers except wrong in your statement about "static" friction applying to sliding while rolling, because that is kinetic friction; which, can also create torque and rotation while sliding.
Likes BvU
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
