Frictional force nonrelated to N
The discussion centers on the phenomenon of friction when the normal force (N) is zero, particularly in the context of a cylinder falling inside a pipe where air cannot escape. Despite the absence of a traditional normal force, the cylinder experiences friction that generates heat due to the compression of air beneath it. Adhesive forces between the cylinder and the pipe wall can also contribute to this frictional effect, even in ideal conditions. The conversation explores the implications of these forces in a vacuum scenario, emphasizing the complexities of friction beyond classical definitions. Overall, the interaction between the cylinder and the pipe demonstrates that friction can occur without a conventional normal force.
Breston
The classical approximated formula describing frictional force is f = N\mu, directed oppositely to the motion direction.
What about that kind of friction that arises when N is 0? How can I account of that?
For example, suppose I let a cylinder fall inside a pipe nearly the same size, so that air cannot slip through the cylinder and the pipe. The motion is perfectly vertical (parallel to gravitational force). The cylinder falls slowly than it would otherwise, and produces heat on the surface of the pipe, displaying evident friction. Still, no vector N exists since the cylinder is falling and does not stand on a surface.
You are saying that it would produce heat so how it would have produced heat if it had not contacted to the pipe? You can imagine this motion such as an object being pushed on a frictional surface.
If you have air being compressed by the cylinder, the air heats up. As for the wall, even with zero normal force, and ideally smooth surfaces you can have adhesive forces between wall and cylinder:
http://en.wikipedia.org/wiki/Adhesion
It is supposed that we do not let air get into the pipe so there could be found nothing in between to have made it heated.
As I understand it, the air cannot pass between cylinder and pipe. But the air under the cylinder is still being compressed, and exerts pressure on the cylinder bottom.
If the OP is mainly interested in the interaction with the wall, then let's assume it's all in vacuum.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
