Automotive Front Wheel Drive or Rear Wheel Drive has higher maximum slip ratio?
The discussion centers on the relationship between maximum slip ratio and the type of drivetrain, specifically front-wheel drive (FWD) versus rear-wheel drive (RWD). It highlights that FWD vehicles generally have better traction due to the engine's weight being over the front wheels, making them more effective in adverse conditions like snow and rain. However, RWD vehicles are noted for better performance during turns. The graph referenced illustrates that both drivetrain types can achieve the same maximum slip ratio, as slip is necessary to generate friction. Ultimately, the normal force acting on the tire is a more significant factor than whether the vehicle is FWD or RWD.
calvinyeh
The graph is relationship between longitudinal force and slip ratio under the conditions of 0 longitudinal acceleration and flat road(0 angle of inclination). Which line represent FWD or RWD? Does FWD or RWD have higher maximum slip ratio?
241046
too general a question - there are rear wheel front engine vehicles
there are rear whee rear engine vehicles
there are front wheel drive front engine vehicles and the one i really like is
Front wheel drive rear engine vehicle
Buckminster Fuller ( who should have stuck with geodesic domes) introduced the
Dymaxion Chronofile ... i can't make this stuff up!
all with different handling characteristics ..slip ration being one , aspect two dimensional
In this case they are both front engine
Ok , let us think about this. I assume the chart is for the front tires, correct? Both front engines. which will be able to provide more traction when cornering and why? You have the same forces ( gravity) at static. Why will one be able to handle the straight line momentum better when in a turn? why is this? Both are same tire width, diameter and compound.
The chart is a nice chart but it is just that..a nice chart. there are many many posts relating to tire slip angle on this very mechanical eng forum..suggest you do a search and read upon these.
From what I have found, generally FWD vehicles have better traction because the weight of the engine and transmission are over the front wheels. This means better traction in snow and rain than RWD. But RWD has better performance when turning. So does it mean FWD will have a higher maximum slip ratio(before vehicle start slipping) which refers to line 1 in the graph?
The graph you shown is related to a tire, regardless of where it is mounted.
The two cases shown on the graph have both the same maximum slip ratio: 1. When the slip ratio is not equal to zero, the tire is slipping. Slip is necessary to create friction, and thus a friction force (Longitudinal force on the graph). The graph shown relates to the concept of static & kinetic friction like this:
The friction force increases linearly in the 'static' region (close to 0 slip); The peak region on your graph relates to the region where it switches from static to kinetic friction. It then stabilizes at a lower constant force at slip ratio = 1.
The difference between the two cases is most likely the normal force acting on the tire. Whether it is RWD or FWD is irrelevant.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
