FTL Gravity Waves: Is Faster-Than-Light Travel Possible?
In summary: A gravity wave is not just a "cyclical expanding and contracting of a region of space". It is a specific type of wave in spacetime with specific properties and behaviors.In summary, gravitational waves travel at the speed of light, while spatial expansion does not have a well-defined speed and does not propagate like a wave. The direction of the gravitational pull also does not propagate, as evidenced by its lack of aberration. The implied analogy between gravitational waves and spatial expansion is not valid, as they are different spacetime geometries with different properties.
Ontophobe
60
On the one hand, gravity waves travel at c, but on the other hand, spatial expansion has no speed limit; ie, it can happen at FTL speeds. At first one might think, "So what? Gravity waves are gravity waves and spatial expansion is spatial expansion." But what is a gravity wave other than the cyclical expanding and contracting of a region of space for some duration? Seems to me like they shouldn't have a speed limit either. But if they can't propagate faster than c, then doesn't that mean Alcubierre drives are impossible? Since a vessel using an Alcubierre drive is really just a surfboard riding a gravity wave of it's own design and creation?
You probably mean gravitational waves. Gravity waves are something different (e. g. surface water waves).
Spatial expansion does not even have a well-defined speed. You can measure how the distance changes, but this is not a relative speed of objects anywhere.
No, and the argument does not make sense.
Spatial expansion just doesn't propagate. You may think it "should" propagate, , but it turns out it doesn't. Another thing that doesn't propagate is the direction of the gravitational pull (or, for that matter, the direction of an electrostatic pull). The apparent position of the sun as observed visually (by light waves) changes due to the Earth's velocity, a phenomenon known as "aberration". Star positions change due to aberration too, a phenomenon known as "stellar aberration" that has to be routinely taken into account in astronomy. However, the actual direction of Newtonian gravity is well known NOT to aberrate in such a fashion. Note that this matches the behavior of the electrostatic force, which also do not aberrate.
The main point I'm trying to make is that the presence or absence of aberration can serve as an experimental distinction between things which we consider to propagate, and things which we do not consider to propagate. The second point I'm making is that using this experimental distinction, we can say that waves propagate (because they do aberrate), while other gravitational effects (such as the direction of the Newtonian gravitational pull) do NOT propagate because they do not aberrate.
I don't have any references for the non-aberration of spatial expansion, but there are some references on the non-aberration (and hence non-propagation) of the direction of gravitational pull. See for instance Steve Carlip's paper, "aberration and the speed of gravity", https://arxiv.org/abs/gr-qc/9909087.
You are assuming that "spatial expansion" is one thing. It isn't. The "spatial expansion" of the whole universe is different from the "expanding and contracting of space" in a gravitational wave. They are different spacetime geometries with different properties, and the implied analogy you are making between them by using the words "spatial expansion" to refer to both is not a valid analogy.
1. Can FTL gravity waves allow us to travel faster than the speed of light?
Currently, there is no scientific evidence or theory that supports FTL travel. According to Einstein's theory of relativity, the speed of light is the maximum speed at which anything can travel. Therefore, it is highly unlikely that FTL gravity waves can enable faster-than-light travel.
2. How do FTL gravity waves work?
FTL gravity waves are a hypothetical concept that proposes the existence of particles or waves that can travel faster than the speed of light. However, there is no scientific evidence or theory that explains how these waves would work or how they could be created.
3. Are there any experiments or studies being conducted to test the existence of FTL gravity waves?
Currently, there are no known experiments or studies being conducted to test the existence of FTL gravity waves. This is because the concept of FTL travel is not supported by current scientific understanding and would require a major breakthrough in physics to even be considered as a possibility.
4. Could FTL gravity waves have any negative effects on the fabric of space-time?
Since there is no scientific evidence to support the existence of FTL gravity waves, it is impossible to determine any potential effects on space-time. However, many scientists believe that FTL travel would violate the laws of physics and could potentially have catastrophic consequences.
5. Is it possible for us to ever achieve FTL travel using gravity waves?
As of now, there is no scientific evidence or theory that supports the possibility of FTL travel using gravity waves. While it is always important to remain open to new ideas and discoveries, it is highly unlikely that FTL travel will ever be achievable.
