Gases I could expect to see using an IR receiver
The discussion centers on identifying gases detectable by an IR receiver operating between 110 and 330 nm, with a focus on the appropriate glass type that won't interfere with results. Participants clarify the wavelength range, noting it includes the blue end of the visible spectrum and extends into UV, and suggest looking into sources like Chem./Phys. Abstracts for specific gas data. There is also a query about the setup for infrared spectrometry, including the need for both an infrared source and a separate light source, and the use of a beam splitter. Concerns are raised about ensuring adequate infrared light reaches the detector after passing through various components. Overall, the conversation emphasizes the technical aspects of gas detection using infrared technology.
bertopolis
Hi I was wondering if someone could tell me what kind of gases I could expect to see using an IR receiver between the wavelengths of 110 and 330 nm. As well as this id love to know what kind of glass could be used in order to not interfere with the actual results.
Thanks a million
bertopolis said:
IR receiver ... 110 and 330 nm
Check your numbers. You've listed blue end of visible, and into UV.
sorry i meant cm^-1
Vibrations of weak bonds, rotations. Fill in the blanks for weakly polyatomic molecules with heteronuclear bonds.
Would you know anywhere that could be a source of the wavelength of gases in this interval? I've been trying to find what gases could be found here for various weeks, although my more pressing question is what glass type can be used in order for results to not be affected.
Thanks for all your help
You want a "Sadtler" for very far IR, into radar/microwave range?
There may be such, " http://www.lib.utexas.edu/chem/info/sadtler.html ," but if UT says it's beyond their budget, I'm sure it's beyond mine to even browse for compiled data. Your best bet is going to be Chem./Phys. Abstracts, or Sci. Cit. for specific compounds that interest you.
Likes bertopolis
Thanks a Million.
I just learned that when doing infrared spectrometry there must be an infrared source and another light source( eg. He Ne laser) but of course both these would need individual detectors, would this be done by placing a beam splitter at the exit of the spectrometer after the light has been "in contact" with the gas source?
And given that the source is a weak infrared diode and the infrared detector is a photo-diode, how can one insure there is sufficient infrared light reaching the detector once it has passed through the spectrometer/interferometer, source and possibly the beam splitter?
Thanks
