Is the QED Action Invariant Under Gauge Transformation?
Cirrus79
Hello,
I don't understand two steps in solution to the problem:
I. Homework Statement
Show that QED action is invariant under gauge transformation.
II. Relevant equations
QED action:
S= \int{d^{4} x \left[\overline{\Psi}\left(i\gamma^{\mu} D_{\mu} -m \right)\Psi -\frac{1}{4}F_{\mu \nu}F^{\mu \nu}\right]}
Gauge transformation:
\Psi\rightarrow e^{-iQ\chi}\Psi
A_{\mu}\rightarrow A_{\mu}+\frac{1}{e}\partial_{\mu}\chi
III. The attempt at a solution
1. First I show that D_{\mu}\Psi\rightarrow e^{-iQ\chi}D_{\mu}\Psi
D_{\mu}\Psi=(\partial_{\mu}+ieQA_{\mu})\Psi \rightarrow<br /> \left[\partial_{\mu}+ieQ\left(A_{\mu}+\frac{1}{e}\partial_{\mu}\chi\right)\right] <br /> e^{-iQ\chi}\Psi =
=\left(\partial_{\mu}+ieQA_{\mu}+iQ\partial_{\mu}\chi\right) <br /> e^{-iQ\chi}\Psi=
=e^{-iQ\chi}\left(-iQ\partial_{\mu}\chi+ieQA_{\mu}+iQ\partial_{\mu}\chi+\partial_{\mu}\right) <br /> \Psi=
=e^{-iQ\chi}\left(\partial_{\mu}+ieQA_{\mu}\right) <br /> \Psi=e^{-iQ\chi}D_{\mu}\Psi
The problem is in the third line. Where does \partial_{\mu} come from?
I get:
(iQ\partial_{\mu}\chi) <br /> e^{-iQ\chi}\Psi=\left(e^{-iQ\chi}iQ\partial_{\mu}\chi -e^{-iQ\chi}i^{2} Q^{2}\chi\partial_{\mu}\chi\right)\Psi
What am I doing wrong?
2. Then I show that F^{\mu \nu}\rightarrow F^{\mu \nu} and \overline{\Psi}\rightarrow e^{iQ\chi}\overline{\Psi}
3. And finally:
\overline{\Psi}(i\gamma^{\mu} D_{\mu} -m)\Psi\rightarrow e^{iQ\chi}\overline{\Psi}(i\gamma^{\mu}e^{-iQ\chi}D_{\mu}-m)e^{-iQ\chi}\Psi=
=e^{iQ\chi}\overline{\Psi}e^{-iQ\chi}(i\gamma^{\mu} D_{\mu} -m)\Psi=\overline{\Psi}(i\gamma^{\mu} D_{\mu} -m)\Psi
Here is the second problem. I get:
=e^{iQ\chi}\overline{\Psi}(i\gamma^{\mu}e^{-iQ\chi} D_{\mu}e^{-iQ\chi} -e^{-iQ\chi}m)\Psi =e^{iQ\chi}\overline{\Psi}e^{-iQ\chi}(i\gamma^{\mu} D_{\mu}e^{-iQ\chi} -m)\Psi
I can't figure out what happens here.
I will be very grateful for your help.
that is one weird way of doing this
I don't understand your first problem since the derivative is there in the second line as well and all other previous lines. First thing to understand is that \chi is a coordinate dependent function so its derivative is non trivial. The line you put up of your solution I'm sorry to say is nonsense
the second problem seems to be orthographic in nature or arising from bad definitions, it should be
<br /> \overline{\Psi}(i\gamma^{\mu} D_{\mu} -m)\Psi\rightarrow e^{iQ\chi}\overline{\Psi}(i\gamma^{\mu}e^{-iQ\chi}D_{\mu}-me^{-iQ\chi}) \Psi<br />
since \overline{\Psi }&#039; (i\gamma^{\mu} D&#039;_{\mu} -m)\Psi &#039; = e^{iQ\chi}\overline{\Psi}(i\gamma^{\mu}D&#039;_{\mu}-m)e^{-iQ\chi} \Psi
and you have already shown that D&#039;_{\mu} \Psi &#039; = e^{-iQ\chi} D_{\mu} \Psi
Can you provide a reference to better solution for this problem? This one is from lecture notes.
This made me think, and i realized that I should use (fg)'=f'g+fg' to the first \partial _{\mu} not the second one. Now I get it.
Of course. I tried to transform \Psi twice.
Thank you very much!
With all due respect, but the problem you're trying to solve is logically circular. The Noether procedure to couple the free fields specifically uses the invariance of the overall coupled action to derive the coupling term. Otherwise, the j^{\mu}A_{\mu} coupling couldn't be derived.
I think you're turning a simple exercise into something it was never intended to demonstrate
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
