Estimating Car Weight from Tire Pressure
In summary, the gauge pressure in each of the four tires of an automobile is 240 kPa and each tire has a "footprint" of 220 cm2. Using the equation P = F/A, the estimated mass of the car is 2155 kg.
A_Munk3y
72
The gauge pressure in each of the four tires of an automobile is 240 kPa. If each tire has a "footprint" of 220 cm2, estimate the mass of the car.
F= ma ?
W1 = P1A1 ?
total weight = W1+W2+W3+W4 = P(A1+A2+A3+A4) <------- since all tires have same surface area and same pressure.
240pka(2.2m^3 x 4) = 2112 kg??
dont think i did that right
You are confusing gauge pressure and absolute pressure. Look up the definition of gauge pressure.
Welcome to PF!
Hi A_Munk3y! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
A_Munk3y said:
… If each tire has a "footprint" of 220 cm2, estimate the mass of the car.
erm :redface: … 220 cm2 = 220 m2/? :smile:
P = F/A ---- is that it?
(try using the X2 tag just above the Reply box :wink:)erm :redface: … 220 cm2 = 220 m2/? :smile:
its 220 cm2 = 0.022m2 isn't it :redface:
ok let me try this again :P
attempt 2
Pressure = Force/Area = Mg/Area = Pa
kPa= = 1000 pa
240Kpa x 1000 pa/kpa = 240,000 pa240,000 pa x 4 tires = 9.8 x m/ 880cm2(1/100)2
960,000 = 9.8m/0.088m2
or does the pressure remain 240000 (you don't add it?)
so its 240,000 = 9.8m/.088m2
m= 2155.1 kg?
Hi A_Munk3y! :smile:
(just got up :zzz: …)
hmm … you're really not good at units, are you? :wink:
how about kN instead of kg? :smile:
(that slipped past me last night! :rolleyes:)
(just got up :zzz: …)hmm … you're really not good at units, are you? :wink:
nope, i completely suck at units! >:(
so you mean 240,000 = 9.8m/.088m2 is still not right ? :frown:
ah, you did put the 9.8 in in post #5 …
yes, m = 240 x 88 / 9.8 = 2155 kg looks right (and I think 2000 kg is a fairly average car weight in the USA). :smile:
ok! w000t!
thank you so much :)
1. How accurate is estimating car weight from tire pressure?
Estimating car weight from tire pressure is not a completely accurate method, as there are many variables that can affect the tire pressure such as temperature, tire wear, and load distribution. However, it can provide a rough estimate of the car's weight.
2. What is the formula for estimating car weight from tire pressure?
The formula for estimating car weight from tire pressure is weight = (tire pressure x tire width) / (tire height x tire aspect ratio).
3. Can this method be used for all types of vehicles?
This method can only be used for vehicles with standard tire sizes and pressure recommendations. It may not be accurate for vehicles with non-standard tire sizes or those with heavily modified or custom tires.
4. Are there any safety concerns when estimating car weight from tire pressure?
There are no safety concerns associated with estimating car weight from tire pressure as long as the tire pressure is within the recommended range for the specific vehicle. However, it should not be relied upon as the sole method for determining weight for towing or other weight-sensitive activities.
5. How can I ensure the accuracy of my estimate?
To ensure the accuracy of your estimate, it is recommended to check the tire pressure with a reliable tire pressure gauge and use the recommended tire pressure for your specific vehicle. Additionally, it is important to consider other factors such as temperature and tire wear when using this method.
18K
9K
9K
