etotheipi
In derivations of capacitance it is standard to consider two oppositely charged, infinitely thin sheets. If we construct a Gaussian cylinder across one sheet, we obtain ##E_{1} = \frac{\sigma}{2\epsilon_{0}}## for one sheet, and then we can superpose this field with that from the other at an arbitrary point between the plates to obtain the result ##E = \frac{\sigma}{\epsilon_{0}}##.
However, a (slightly...) better model of a capacitor might be one with plates which are still infinite, but now have some thickness. One plate has a charge ##Q## and the other ##-Q##. Since the electric field is zero inside the conducting plates, the electric field strength at the surface of the plate is now just ##\frac{\sigma}{\epsilon_{0}}## (as is the case with any other conductor) since we only have to count flux through one end of the cylinder which contains a small section of the surface. Likewise, the electric field strength at any point outside the other plate due to the other plate also has to be ##\frac{\sigma}{\epsilon_{0}}##. When we superpose the two electric fields, the total electric field strength between the plates is ##\frac{2\sigma}{\epsilon_{0}}##,... but that can't be right!
I can't however see where the second approach fails. The plates are still infinite so due to the symmetry of the infinite plane the field must still always be orthogonal to the sheet, and so the field strength at an arbitrary point on that side of the sheet must be the same as that at the surface.
The only resolution I can think of is that the field strength inside the plate is non-zero, though this goes against standard theory for conductors (since then the charges would just move until an equipotential volume was again obtained). Any guidance would be appreciated, thank you!
