Gaussmeter wire electric field
weijey1
A simple gaussmeter for measuring horizontal magnetic fields consists of a stiff 50 cm wire that hangs from a conducting pivot so that its free end makes contact with a pool of mercury in a dish below. The mercury provides an electrical contact without constraining the movement of the wire. The wire has a mass of 1 g and conducts a current downward.
(a) What is the equilibrium angular displacement of the wire from vertical if the horizontal magnetic field is 0.04 T and the current is 0.20 A?
(b) If the current is 20 A and a displacement from vertical of 0.5 mm can be detected for the free end, what is the horizontal magnetic field sensitivity of this gaussmeter?
(a) The equilibrium angular displacement of the wire from vertical due to the magnetic field is given by the equation $\theta = \frac{\mu_0 I L B}{2 mg}$, where $\mu_0$ is the permeability of free space, $I$ is the current, $L$ is the length of the wire, $B$ is the magnetic field, and $m$ is the mass of the wire. Substituting the given values into the equation gives $\theta = \frac{(4 \pi \times 10^{-7})(0.2 \text{ A})(0.5 \text{ m})(0.04 \text{ T})}{2 (1 \text{ g})} = 1.26 \times 10^{-4} \text{ radians}$. (b) The sensitivity of the gaussmeter can be determined from the equation $\frac{\Delta B}{B} = \frac{\Delta \theta}{\theta}$, where $\Delta B$ is the change in the magnetic field, $B$ is the magnetic field, $\Delta \theta$ is the change in the angular displacement of the wire, and $\theta$ is the angular displacement of the wire. Substituting the given values gives $\frac{\Delta B}{B} = \frac{0.5 \times 10^{-3} \text{ m}}{1.26 \times 10^{-4} \text{ radians}} = 3.97 \times 10^3 \text{ T}^{-1}$. Therefore, the sensitivity of the gaussmeter is 3.97 mT/A.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
