How Do You Calculate Electric Flux Through a Nonuniform Field?
To calculate electric flux through a nonuniform electric field described by E = ay^i + bz^j + cx^k, the dot product of the electric field and the differential area element dA is taken, focusing on the z-axis component. The expression simplifies to cxdA, leading to the need for a double integral over the rectangular surface in the xy-plane. The correct approach involves evaluating the double integral as c * ∫(0 to w) x dx * ∫(0 to h) dy, since the limits are constant. The flux contributions from the i and j components are zero, confirming that only the k component is relevant. Ultimately, this method yields the expected result of (1/2 chw^2).
rambo5330
Can someone please help me work through this problem I've spent over an hour on this trying to figure out what to do.. here's the question
A nonuniform electric field is given by the expression E = ay^i + bz^j + cx^k,
where a, b, and c are constants. Determine the electric flux through a rectangular
surface in the xy plane, extending from x = 0 to x = w and from y = 0 to y = h.
this question can be viewed better here http://web.uvic.ca/~jalexndr/week%203%20problems.pdf (question #54)
i basically use gauss's law and get it down to something like
= C\int (x dA )
my method here was two take the dot product of the electric field and dA which is said to be perpendicular to the surface in the x y plane therefore it will act along the z axis
so this dot product comes out equalling cxdA where c is a constant... where do i go from here.. the answer is given as (1/2 chw^2)
You have the right answer. To evaluate your expression, use dA = dxdy, so now you have \int\int{x*dxdy} with x going from 0 to w, and y going from 0 to h. If you go through the steps, you will get the same answer.
Oh excellent, so judging by what you wrote to continue past where I left off it involves a double integral? if this is the case I have not learned the double integral yet this semester which makes more sense why I as so stuck ..
well, this case does not have variables x or y in the limits. do the definite integrals separately and just multiple the results together. so it'll be like this c*\int_{0}^{w}xdx*\int_{0}^{h}dy
Your surface is in XY plane
flux due to field in i and j derection is 0
only k left, which i assume is easy!
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
