Deriving Electric Field in a Charged Rod and Shell System"
  • Thread starter Thread starter chillaxin
    Gauss's law Law
A long straight conducting rod with a linear charge density of +2.0 µC/m is enclosed by a cylindrical shell with a charge density of -2.0 µC/m. To find the electric field between the rod and the shell, a Gaussian surface is used, considering only the positive charge of the rod for calculations. The electric field outside the shell is determined to be zero due to the total enclosed charge being zero. The discussion emphasizes that the electric field is not constant between the rod and the shell, and the calculations must reflect the specific regions being analyzed. Understanding the charge distribution is crucial for accurately deriving the electric field in both scenarios.
chillaxin
A long straight conducting rod (or wire) carries a linear charge density of +2.0uC/m. This rod is totally enclosed within a thin cylindrical shell of radius R, which carries a linear charge density of -2.0uC/m.
A) Construct a Gaussian cylindrical surface between the rod and the shell to derive then electric field in the inner space as a function of the distance from the center of the rod.
B) Construct a Gaussian cylindrical surface outside both the rod and the shell to calculate the electric field outside the shell.
This is what i have so far.
E=q/4piEor^2
E=+2.0uC/m / 4pi8.85x10^-12(-2uC/m)^2
E=4.5x10^9Nm^2/C
Anybody?!?
E=q/4piEor^2
E=4.5x10^9Nm^2/C
The field is certainly not constant in the region between the rod and the cylinder. Are these anwers to multiple parts? Just the first part?
Unless I'm mistaken, the total charge inclosed in the whole system is zero. If the enclosed charge is zero, the electric field is zero. Thus from what I can draw, the answer to B is zero. The answer to A requires using the enclosed charge to be the positive portion and then solving for E.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
