r16
- 42
I was thinking about gauss's law and ran into this contradiction.
Consider this situation in electrostatics. You have an infinite line of charge, uniform charge density [text]\lambda[/tex]. In cgs units, E at a distance r from the line of charge along the +y axis (assuming a left handed coordinate system) is [tex]\frac{2 \lambda}{r}[/tex].
Now consider a right circular cylinder in empty space as a gaussian shape. Intuitively, I will tell you that the net flux is 0 through the entire shape: all field lines that flow into the shape flow out.
But thinking about this analytically gives you a different answer:
Flux through top bottom (closest to the charge) = [tex]-\frac{2 \lambda}{r} (\pi r^2)[/tex]
Flux through sides = 0
Flux through top (furthest away from the charge) = [tex]\frac{2 \lambda}{r + l} (\pi r^2)[/tex]
so the net flux is tex]-\frac{2 \lambda}{r} (\pi r^2) + \frac{2 \lambda}{r + l} (\pi r^2)[/tex] which must be less than 0 because [tex] r > r+l [/tex], which would mean that there is a net negative flux, or some sort of negative charge enclosed in the gaussian surface which is contradictory to the intuitive evaluation of the shape.
Any resolution to this contradiction?
