GE90-115B Turbofan Engine: Thrust Analysis
The discussion focuses on increasing thrust in high bypass ratio turbofan engines, specifically the GE90-115B, which delivers a total thrust of 115,000 pounds. Participants seek to understand the thrust contributions from bypass air and hot exhaust gas. While specific thrust fractions are not readily available, estimates suggest that exhaust thrust could be around 20,000 pounds based on similar technologies. Resources such as NASA's website and thermodynamic relations for turbofan cycles are recommended for further exploration of thrust calculations. The conversation emphasizes the importance of knowing the velocities of both the jet exhaust and bypass flow for accurate thrust analysis.
vincentryan
Hi,
i am trying to increase the jet engine thrust. today most of the aircrafts are using high bypass ratio turbofan engine. thurbofan engine delivers thrust in two steps
one: hot exhuast gas
second : by pass air
how i have to find the thrust developed by the bypass air?
how i have to find the thrust developed by the hot exhaust gas?
GE90- 115B turbofan engine delivers total thrust of 115,000 pounds of thrust, in that how much amount of thrust delivered by the bypass air and by the hot exhaust gas?
Welcome to PF, Vincent.
I believe that Fred Garvin is the guy to answer your questions. Bear in mind, though, that since he designs jets for a living, he won't give you any proprietory information.
I'll defer to Fred on this, but I've looked at lots of articles and not one showed the fraction of thrust from the jet exhaust or bypass flow. I would guess that the exhaust thrust is about 20,000 lbs or so, based on the CFM56 technology.
http://www.cfm56.com/index.php?level2=engines&level3=1126
I did find some cool stuff though.
http://www.snecma.com/IMG/pdf/GE90_Anglais-2.pdf
http://www.ihi.co.jp/ihi/file/technologygihou2/10006_1.pdf
See also - http://books.google.com/books?id=VpJEm7cFVE4C&pg=PA26&lpg=PA26&dq=%22jet+engine%22,%22bypass+ratio%22&source=web&ots=z26WF1wyEI&sig=-kAx30UTrX4CaJpK5dAN_hJeMTE&hl=en#PPA21,M1
http://en.wikipedia.org/wiki/GE90
answer
Thanks for your reply. i have found answer for my question from the NASA Website. please clilk on the link to know about turbofan thrust equation.http://www.grc.nasa.gov/WWW/K-12/airplane/turbfan.html"
That is exactly correct. However, you will not always know the velocities of each stream as required by that page. You may need to delve farther into the thermodynamic relations for the turbofan cycle. You may look to this (usually one starts with known conditions at the inlet and works their way to the back end of the engine):
http://en.wikipedia.org/wiki/Jet_Engine_Performance
Just as Fred mentioned, one needs to know the velocities of the jet exhaust and bypass flow (exit).
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
10K
