Calculating Gear and Gearbox Torque
  • Thread starter Thread starter yew105
    Gear Torque
To calculate gear torque for gearboxes like worm reduction and helical gearboxes, start with the input torque from the motor and multiply it by the gear's reduction ratio. It's important to account for mechanical losses, typically around 10%. The torque can be calculated using the formula τ = r * F, where torque equals radius times force. For example, if the input torque is 10Nm at 10 RPM and the output gear has double the radius, the output torque will be 20Nm at 5 RPM. Utilizing engineering handbooks or software can further assist in these calculations.
yew105
Somebody tell me how to calculate gear torque for gears and also for engineering gearbox like worm reduction gearbox and helical gearbox. Any software or hand book is available to find out gear torque and gearbox torque ?
Please help me.
Thanks
Satish Patel
Well, it depends on your input torque. If you have a motor diving your gear, look up the torque coming out of the motor (or calculate it) and then multiply that torque by the reduction ratio. Also, you will lose torque just by the nature of the mechanics. You could factor in a loss of 10% to be safe.
Otherwise, torque for a gear is
τ = r * F
torque = radius * Force
If you have a input of 10Nm of torque at 10 RPM, and your output gear has twice the radius of the input gear, your Torque will double and your speed will halve. You will end up with 20Nm of torque and 5 RPM.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
