General help understanding emf and p.d
  • Thread starter Thread starter Gregg
    Emf General
The discussion revolves around understanding the concepts of electromotive force (emf) and potential difference (p.d.) in the context of a battery's internal resistance. Participants are examining a graph that illustrates the relationship between p.d. across a battery and current as resistance is varied.
  • Participants discuss the relationship between emf, p.d., and internal resistance, referencing Kirchhoff's laws. There are attempts to derive equations from the graph and interpret the gradient and intercept. One participant raises a question about the proportionality of V and I in different contexts.
Some guidance has been provided regarding the interpretation of the graph and the mathematical relationships involved. Multiple interpretations of the relationship between voltage and current are being explored, particularly in relation to different types of conductors.
There is an indication of confusion regarding the concepts of internal resistance and the behavior of V and I in different scenarios, as well as a request for examples and explanations to clarify these concepts.
Gregg
Graph to show the variation of the p.d. V across the battery with current I as R is varied.
i) Draw line of best fit.
ii) Use it to determine the emf of the battery;
and the internal resistance r of the battery.
The gradient [itex]\approx \frac{\Delta V}{\Delta I} = 1.67 \Omega[/itex]
Just don't know what to do really. Need an example and explanation of the concept.
Let the internal resistance of the battery be r.
The same current,I, passes through both r and R right?
So by Kirchoff's 2nd law
the emf of the battery=sum of the pd's around the loop
If V is the pd across the load then
E=V+Ir.
Since they plotted V against I, rearrange the equation it in the form a straight line y=mx+c
you calculated the gradient correctly to give a resistance. So rearrange the equation and you will see what that gradient represents and what the intercept represents as well.
[itex]V = f(I)[/itex]
[itex]V = -Ir + E[/itex]
y-intercept is emf, gradient is -r. Thanks.
Hi I had a similar question, which I posted at the the thread 'internal resistance graph'. It was basically why are V are I inversely proportional in this graph, but proportional in the graph of an ohmic conductor?
  • · Replies 25 ·
  • · Replies 22 ·
