pervect said:
Yes, apparently the OP's intuition is leading him astray somehow. I'm not quite sure how, exactly. Currently, all I"m hoping for is that he'll realize from the number of SA's and other posters that are disagreeing with his conclusions (about Newtonian gravity, nevermind general relativity) that he probably made a mistake somewhere.
It's hard to tell what the OP's background is in order to help him figure out where he's gone astray. From the lack of calculus in any of his arguments, I' suspect the OP's background probably doesn't include calculus :-(.
I haven't seen calculus in any posts, so I don't know why you are taking me to task for this. But regardless, I was trying some calculus solutions with my father yesterday (who is a mechanical engineer). One thing you will notice if you try it is that this is a huge, complex problem. Really, you can't calculate it with high precision overnight unless you are very obstinate, there are so many things to consider. But there's a way to solve it very roughly with algebra:
- Position the moon vertically with the axis aligned towards the earth.
- Divide the mass of the moon equatorially in two halves so that each half has the length of one moon radius and diagram each center of mass
m1 and
m2. Consider each half as a cube with half the volume of the moon - this will give you a block shape)
- Find the lengths of the sides of the cubes.
- Put the center of this system
Mm at a distance
D from a point
Me, with
D=moon-earth distance.
- Move the system (the moon) a bit in the direction of the constant innate tangential velocity as if there was no gravity - I moved it half the moon's radius). – You have to so this because if you don't, there's no orbit, no linear velocity and the moon would fall straight to earth, I hope you can see that.
- Turn on Earth's gravity at point
Me and draw both gravity vectors from
Me to point
m1 and
m2 and give them the right magnitudes (the magnitudes are not the same, you have to consider the distance between them - the correct value would be one moon radius, but since we're looking for the forces on the near and far sides I use the magnitudes of gravity on the near and far sides).
- Project the gravity vectors in the opposite direction of the linear innate velocity of the moon at right angles from the vertical axis of the moon (the line connecting
m1,
Mm and
M2) and find their magnitudes.
- Subtract them and find the net force
F.
- You can ditch the Earth now, we won't need it anymore. Apply
F on either point
m1 or
m2 (it doesn't matter because all we have to do now is find out how much a force on one point skews the whole system).
- Consider a moon of iron (or choose the material you find closer to what's the main composition of the moon)
- Find the elasticity modulus of the material
E (you can find it easily on the internet).
- The displacement of the point where
F is applied is
Δb.
- Calculate
Δb:
Δb = FL
3//3EI
where:
I = bh
3//12
h=
b= the length of the sides of the cubes = 1 moon radius
L= the diameter of the moon
If you do this you will see there's no possible way whatsoever that the moon could ever maintain it's shape with no shearing. The forces are too great and the moon is not nearly strong enough to overcome the shear stress.
The value I found for
Δb was so large I can't believe it, either I've done something wrong, or... I don't even want to think about it. I'll take it back to my father to analyze, but meanwhile, why don't you guys try to calculate it and then we can compare the numbers?
The numbers I used are:
3474km - Diameter of the moon
3.84x10
9 - Distance from the center of the Earth to the near side of the moon
3.85x10
9 - Distance from the center of the Earth to the far side of the moon
211 GPa (Giga Pascal) - elasticity module of iron - I took the moon as a ball of iron for simplicity
Notice this gives us a very rough estimate and it's already a bit dense. If you want to do the complete analysis, you have to take the moon as a sphere and do a lot of calculus indeed, but it seems pointless to try and get a more precise number since just for this simple estimate the work is already a bit tiring, and to consider it fully we'd have to know the full composition of the moon, where each element is located, know their densities on the moon, test our numbers against each element (and do it in a laboratory since you won't find these on the net), know the strength of the bonds between the various elements, consider pressure from the inside out (mantle pressure, etc) and outside in (moon's own gravity), plug in the eccentricity of the moon and of it's orbit and on and on and on. Since all our numbers would be rough estimates from the start, I can live with the above analysis. Also see that final number is probably rounded
up, since the moon has mainly 60% the density of the Earth (and so much less pressure and much less rigidity).
I conclude that a body in tidal lock should always be skewed, with the inner side ahead of the far side by a very clear amount, or even breaking up entirely. Either in GR or Newton. If you have forces of torsion, torques and anything like that, the body must suffer distortion. Always. Engineers know this very well and take very much care to consider the forces involved and how much of it a material can take without breaking up.
The point is that, if tidal lock is the result of a torque, the near side of the body should travel ahead of the far side in the direction of orbit, dragging the far side with it, skewing the shape of the body by a large amount. Since there's no absolute rigidity and instantaneous transmission of forces and gravity drops with the square of the distance, I'm starting to think that the only plausible scenario shearing wouldn't happen without reconsidering current theory is if the rotation is innate and just happens to match the orbit period by coincidence, but that can't be, there are too many bodies in tidal lock, too much to be just an accident. There must be a mechanism... but if it is due to torque, the shape of the bodies in tidal lock don't show any sign of it (namely, shearing).
I wasn't expecting this. I thought there should be shearing, but I was open to consider that it was too small to notice, that's why I went and did the calculations. The results just blew me away. I'm starting to believe that no one has ever thought of applying "engineering" equations to check if a body like the moon could hold itself together with the forces predicted/assumed by current theory. We see that it does, so we just assumed the forces were not strong enough to cause any significant stress, but I urge you to try the math yourselves.
Something is wrong.
Or I am wrong and desperately in need a careful consideration of the variables and calculations and a good explanation on why there's no shearing at all in tidal locked bodies.
