What Generators Can Run on 12 kgm Torque and Their Current Output?
Generators that can operate on 12 kgm torque at 60 rpm can produce approximately 0.75 kW of power. This torque translates to 120 Nm, which is calculated using the formula P=T*pi*N/30000. The current output can be determined by dividing the power by the voltage of the generator. While a generator rated for 750 watts is suitable, it may be considered low for some applications. Overall, selecting a generator with the appropriate capacity is essential for optimal performance.
roozer
My project produces 12 kgm torque so,I need a list of Generator which runs on 12 kgm torque and how much Current it produces... Please advise
At what speed does your prime mover apply 12Nm?
It rotates at 60 rpm
So using the torque and rpm, calculate the power (and current is power divided by voltage). Then you can just google for generators that are of that capacity.
okay so 12 kgm torque is 120 Nm and speed is 60 rpm...So using this formula P=T*pi*N/30000
Power is .75 kw.
Now a generator which runs on 750 watts...okay that's a little low...
Thanks
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
