Geometric reps of complex formula
wildman
Describe geometrically the sets of points determined by the relations:
a) |z-i|+|z-1| = 2
b) |z-i|=|z+1|
c) Re z = |z-2|
I know the answer of a is suppose to be Ellipse with foci at i and 1, major axis 2
and b is Perpendicular bisector of the line segment connecting z=i and z = -1
and c is Parabola focus at z=2, directrix the imaginary axis (from the back of the book), but could one of you help me to see how the author got those answers?
The most direct way to handle all of them is to put z=x+iy and look at the x,y equations. You could also look up the geometric definition of an ellipse and a parabola to do those more directly.
Yep. The direct method worked. Thanks.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
