Geometry: I want to understand some points
  • Thread starter Thread starter irony of truth
    Geometry Points
To find the unknown x related to an arc of a great circle 10 units long receding from its chord, the relationship between the radius R and angle alpha is crucial. The discussion suggests that x can be expressed as R - R cos(alpha), representing the maximum distance between the arc and the chord. The geometry involves an isosceles triangle formed by the endpoints of the arc and the center of the circle. Additionally, properties of triangles indicate that the angle can be determined to be 45 degrees, leading to R being calculated as the square root of 50. Understanding these relationships is essential for solving the problem effectively.
irony of truth
What is my unknown (say x) if I am finding the value in which an arc of a great circle 10 units long recedes from its chord? (given radius R and angle alpha?)
Here's my figure as an attachment...
I am guessing, you can express R = xR + (1-x)R where (1-x)R is the height of your (isosceles) triangle and xR is the bit from the chord to the circle.
What do you mean by "recedes from its chord"?
HallsofIvy, seems like the arc is moving away from its respected chord (form by the two enddpoints of the arc)
My friend told me that x = R - R cos (alpha)... I wonder why...
He has given the greatest distance between the arc and the chord i.e. the difference of the radius and distance of the chord from the center
hi
By using the laws properties of triangle you will get the angle to be 45 degrees and
R to be square root of 50
http://www.mathsrevision.net/gcse/pages.php?page=47
