Get time from acceleration given as a function of velocity
The discussion focuses on finding time as a function of velocity when acceleration is expressed as a function of velocity, a(v). The equation t(v) = t0 + ∫vv0 1/a(v) dv is derived from the relationship between acceleration, velocity, and time. Participants express confusion about integrating with respect to velocity when time and velocity are not independent variables. Clarification is provided that acceleration is defined as dv/dt, applicable whether it is a function of time or velocity. Understanding these relationships is crucial for solving the problem correctly.
harmyder
If the acceleration is given as a function of velocity a(v), we can found t(v) as t(v) = t0 + ∫vv0 1/a(v) dv.
I just can't understand there to go to understand the equation..
What is the (calculus based) definition of acceleration?
Likes harmyder
\frac{dv}{dt} = a(t) \rightarrow v(t_1) = v(t_0) + \int_{t_0}^{t_1}a(t)dt
\frac{dt}{dv} = \frac{1}{a(t)} \rightarrow t(v_1) = t(v_0) + \int_{v_0}^{v_1}\frac{1}{a(t)}dv
but it is still not a(v)
How will you integrate f(t)dv? t and v are not independent variables.
Note that acceleration a is dv/dt regardless of if a is a function of time a(t) or a function of velocity a(v)
Likes harmyder
