Gibbs free energy change at constant pressure is zero?
The discussion revolves around the conditions under which the Gibbs free energy change (ΔG) at constant pressure is zero. Participants explore the relationship between Gibbs free energy, enthalpy (ΔH), and entropy (ΔS), particularly in the context of chemical reactions and equilibrium conditions.
  • One participant questions whether the Gibbs free energy change at constant pressure is zero, suggesting a relationship between ΔG, ΔH, and ΔS, but expresses confusion regarding the definitions of heat in these contexts.
  • Another participant points out two assumptions made by the original poster: that heat is exchanged reversibly and that temperature is constant, which are necessary for the stated relationship to hold.
  • A different perspective introduces the idea that during a chemical reaction, Gibbs free energy can change even if pressure and temperature are held constant, due to the reaction coordinate.
  • Further technical details are provided regarding the differential forms of internal energy, enthalpy, and Gibbs free energy, emphasizing the importance of distinguishing between total changes and derivatives with respect to reaction extent.
  • One participant clarifies that the confusion may stem from the difference between total Gibbs free energy change (ΔG) and partial free energy change (Δ_r G), which is often the focus in chemical contexts.
Participants express differing views on the conditions under which ΔG can be considered zero, with some arguing that it is contingent on equilibrium and reversible processes, while others emphasize that it can change during reactions even under constant conditions. The discussion remains unresolved regarding the implications of these conditions.
Participants highlight limitations in the assumptions regarding reversibility and equilibrium, as well as the potential confusion between total changes and partial derivatives in the context of Gibbs free energy.
jd12345
gibbs free energy change at constant pressure is zero??
IS gibbs free energy change at constant pressure zero?
ΔS = q / T. At constant pressure q = ΔH so ΔS = ΔH / T
So ΔG = ΔH - ΔH/T . T
= 0
I think i am wrong but where? My friend tells me that q involved in enetropy is different from the one we consider in ΔH. I don't understand this. IS heat due to entropy different from the one involved in enthalpy change
I'm all messed up
Chemistry news on Phys.org
In my opinion you unwittingly made two assumptions:
1) heat is exchanged reversibly (in the definition of ΔS there is reversible heat)
2) temperature is constant (otherwise ΔG = ΔH - TΔS does not hold, generally ΔG = ΔH - Δ(TS) )
So you have an equilibrium situation with constant T and P in which case G is indeed constant.
When a chemical reaction is involved
then
[itex]dG=Vdp-SdT+\Delta G d\xi[/itex]
where [itex]\xi[/itex] is the reaction coordinate. So even if p and T are hold constant, G will change as a result of the chemical reaction taking place.
The problem with using [itex]\Delta S=q/T[/itex] is that it presuposes equilibrium. However, when there is no chemical equilibrium, the formula is not applicable.
asym said:
I
Not quite,
[itex]dU=TdS-pdV+\sum_i \mu_i dn_i[/itex]
[itex]dH=TdS+Vdp+\sum_i \mu_i dn_i[/itex]
[itex]dG=-SdT+Vdp+\sum_i \mu_i dn_i[/itex]
so [itex]\mu_i=\partial G/\partial{n_i}|_{T,p}=\partial H/\partial {n_i}|_{S,p}[/itex] etc.
For a reaction [itex]\sum_i \nu_i X_i=0[/itex] the reaction coordinate is defined as
[itex]dn_i/\nu_i=d\xi[/itex] and [itex]\Delta G=\sum_i \mu_i \nu_i[/itex].
Hence [itex]\Delta G=\partial G/\partial \xi |_{p,T}=\partial H/\partial \xi|_{p,S}[/itex]
Now by definition
[itex]\Delta H\equiv \partial H /\partial \xi|_{p,T}=\partial H /\partial \xi|_{p,S}+\partial H/\partial S|_{p,\xi}\partial S/\partial \xi|_{p,T}=\Delta G+T\Delta S[/itex] as [itex]\partial S/\partial \xi|_{p,T}\equiv \Delta S[/itex]. So ΔG = ΔH - TΔS holds always.
DrDu said:
Not quite,
Now by definition
You confuse Δ for the total change of a state variable (what I use in my posts) with the derivative (slope) of the variable with respect to the reaction extent, which is unfortunately denoted by Δ as well, nonetheless, there should be subscript r (like reaction) in that case - to distinguish from mere change.
My arguments are independent on the process happening in the system, be it chemical reaction or anything else. If Δ is just change (what is it's original meaning), then ΔG = ΔH - TΔS cannot hold always which is seen immediately from the mere fact that with varying temperature we wouldn't know what value from the range should be used for T:-)
To sum up: we are not in disagreement, we just interpret the question differently. I believe the asker was referring to simple change by Δ, not to the above-mentioned differential quantity, am I right?
Asym,
of course you are right. My impression is that this kind of questions mostly arise because people don't know the difference of the simple [itex]\Delta G[/itex] and the partial free energy change [itex]\Delta_r G[/itex], with chemists having mostly the second one in mind.
12K
