Golf Ball Impact Force: Calculate Velocity & Answer
  • Thread starter Thread starter Unknown_20
    Force Impact
To calculate the average force of impact when a golf ball is struck, first determine the initial velocity using the range formula for projectile motion, which accounts for the launch angle and distance. The horizontal component of the velocity can be calculated, followed by the vertical component, to find the total velocity at impact. Next, use the change in momentum, which is the mass of the ball multiplied by the change in velocity, and divide by the contact time of 10.2 ms to find the average force. The acceleration due to gravity is factored in to ensure accurate calculations. The final average force of impact is expressed in Newtons (N).
Unknown_20
A golf ball (m = 38.6 g) is struck a blow that
makes an angle of 46.3 degrees with the horizontal.
The drive lands 273 m away on a flat fairway.
The acceleration of gravity is 9.8 m/s^2 .
If the golf club and ball are in contact for
10.2 ms, what is the average force of impact?
Neglect air resistance. Answer in units of N.
I found the velocity, where do I go from here?
Force is change in momentum per unit time!
thanks for the help.
