Grade 12 Physics question!
  • Thread starter musicfan31
musicfan31
A 1000 kg plane is trying to make a forced landing on the deck of a large 2000 kg barge at rest on the surface of a calm sea. The only frictional force to consider is between plane's wheels and the deck, and this braking force is constant and equal to one-quarter of the plane's weight. What must the minimum legnth of the barge be, in order that the plane can stop safely on the deck, if the plane touches down just at the rear end of the deck with a velocity of 50 m/s towards the front of the barge? (SIN.'76)
**PLEASE write out the full solution!**
Additional Details
The answer is 3.4*10^2 meters.
2.
work = force applied * displacement
momentum = mass*velovity
m1v1 + m2v2 = m1v1' + m2v2'
3.
Plane
m = 1000 kg
Vi = 50m/s
Vf = 0 m/s
Barge
m = 2000kg
Vi = 0 m/s
Force of friction = force of normal = mass*g
m1v1 + m2v2 = m1v1' +m2v2'
1000(50) + 2000(0) = 1000(0) + 2000v2'
1000(50)
________ = v2'
2000
25 m/s = v2' = speed of barge in oppsite direction
** I DUNT EVEN NOE IF THE STUFF I DID ABOVE IS RIGHT*** BUT NOW I"M LOST**** HELP MEEE***
Answers and Replies
Doc Al
Mentor
45,462
1,951
This isn't correct. Reread what the problem tells you about friction.
The collision is inelastic--the plane and barge end up moving with the same speed. (The final speed of the plane isn't zero.)
Find the final speed of the barge and plane.
What's the acceleration of the plane? What distance does it take to bring it to its final speed?
What's the acceleration of the barge? What distance does it move during its acceleration?
musicfan31
I have no clue as to what you are speaking of... the final speed of the plane is not Zero?
Then what is the number that needs to be subbed in as final velocity of the plane.?
Doc Al
Mentor
45,462
1,951
That's right. The plane ends up moving at the same speed as the barge. (It better, or it will just fall off the barge!) Use momentum conservation to find the final speed of barge and plane.
Here is a solution but I can't make any sense of this you can help me figure this out.
That solution is precisely the one I'm trying to get you to figure out for yourself.
musicfan31
okay the Ff = 1/4M*g
= 1/4(1000)*9.8
= 250*9.8
= 2450 Newton is the force of friction
musicfan31
The conservation of momentum formula is :
musicfan31
I go it ! I GOT IT!
Thank YOU DOC AL
dpaquette
I'm still stuck. Can you give more help?
Suggested for: Grade 12 Physics question!
  • Last Post
