Graduate Engineering - Linear Algebra (Graham Schmidt + more)
Koolaidbrah
No idea how to solve this using graham schmidt. I know how to do graham schmidt and how to solve this problem if I didn't have to use graham schmidt, but I have no idea where to start in order to get my vectors to add to V
Found c to be 87 by using vector addition/subtraction and making it linearly dependent on other two.
However, not sure how to find two vectors that are in span and perpendicular that add up to V just like in #1
For b., as long as A is invertable, wouldn't it be all of the b vectors?
Graham Schmidt...
Posted above
Well, if the question was not asking you to use the procedure, you could easily solve the augmented system and exhibit a solution.
The point of the gram process though, is to take a set of linearly independent vectors say S, in your space and to form a orthogonal set of vectors T by using the process. The span of the new set of vectors will be equivalent to the span of your original set.
That is, span{T} = span{S}.
You could go even further and form an orthonormal set out of the vectors of T, but it's not required here. Finding the set T should be sufficient.
Should I use my first two vectors in my set to find the first orthogonal vectors and the third as {1 2 3} to find the vector V2 perpindicular to my span? From there {1 2 3} minus the V2 vector to get my V1
I'm just confused as to how I use V1 is in span, V2 is perp to span and V1+V2 = {1 2 3}
Out of curiosity (I'm learning gram schmidt for the first time in my LA class), what application does this have to engineering? (Thinking of going into engineering)
Yeah, that'll work if you're planning to do what I think you're saying.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
