Punkyc7
- 415
Prove that if G is a simple graph with at least two vertices, then G has two or more vertices of the same degree.
Pf/
Assume its true for the base case 2 vertices with no edges or 2 vertices with one edge. Then either the degree is of both is 0 or the degree of both is 1. Therefore both vertices have the same degree.
Now assume true for K vertices. WTS True for K+1 vertices.
Since its true that K vertices have at least one pair of vertices of the same degree it follows immediately that K+1 vertices have at least one pair of vertices of the same degree.I was also thinking about doing this by contradiction and showing that if all the vertices are different degrees then there must be a loop but I was not sure how to say that.
Pf/
